posi confusion #1046576
08/03/11 01:02 PM
08/03/11 01:02 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
I can't remember which was which - posi unit what was the open ? closed? pics? im confused
Re: posi confusion [Re: mro] #1046577
08/03/11 01:04 PM
08/03/11 01:04 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Why are you asking about Gm products on a Mopar forum?
Re: posi confusion [Re: drew72] #1046578
08/03/11 01:05 PM
08/03/11 01:05 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sure grip is mopar for posi and open is just that open.
I have mechanical Aptitude.
I can screw up anything.
Re: posi confusion [Re: mro] #1046579
08/03/11 01:07 PM
08/03/11 01:07 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
"Posi-Trac" is actually a GM term used for GM's limited slip differential. Chrysler called their limited slip differentials the "Sure Grip". Generally speaking, a "Posi" is a limited slip differential.
EDIT: I got treed, big time.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: posi confusion [Re: bigsbigelow] #1046580
08/03/11 01:10 PM
08/03/11 01:10 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Guy - I know its called sure grip - to humanity its a posi. I don't come on here to have my nads cracked. I come on here for help when I need it and I HELP ALOT OF PEOPLE HERE IN RETURN SO COOL YOUR JETS GM BOY.
68 Satellite Wagon and a few other ones
Re: posi confusion [Re: mro] #1046581
08/03/11 01:12 PM
08/03/11 01:12 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Meoow
Lighten up your self cat women
Re: posi confusion [Re: mro] #1046582
08/03/11 01:26 PM
08/03/11 01:26 PM
bigsbigelow Offline
bigsbigelow  Offline
If this reply was directed to me:
I meant no disrespect. The question you asked is a beginners question, plain and simple. I figured I would help you out and explain the correct terminology. I don't crack nads, I try and enlighten when I can. Sorry you were offended.
Re: posi confusion [Re: mro] #1046583
08/03/11 01:32 PM
08/03/11 01:32 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
An "open" differential is what you might also have seen called the one wheel wonder
Re: posi confusion [Re: BEINGmeISaCRIME] #1046584
08/03/11 02:16 PM
08/03/11 02:16 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Sorry - crappy day -
I don't remember like I used to - the unit has the window through the casing and I can see the clutch springs - thats the closed right?
Re: posi confusion [Re: BEINGmeISaCRIME] #1046585
08/03/11 02:17 PM
08/03/11 02:17 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
And by the way - it was directed at DREW.
Re: posi confusion [Re: mro] #1046586
08/03/11 02:20 PM
08/03/11 02:20 PM
bigsbigelow Offline
bigsbigelow  Offline
Yes. More specifically, it is the cone type Sure Grip.
Re: posi confusion [Re: bigsbigelow] #1046587
08/03/11 02:23 PM
08/03/11 02:23 PM
bigsbigelow Offline
bigsbigelow  Offline
Re: posi confusion [Re: bigsbigelow] #1046588
08/03/11 02:29 PM
08/03/11 02:29 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
thanks
Re: posi confusion [Re: mro] #1046589
08/03/11 02:47 PM
08/03/11 02:47 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Re: posi confusion [Re: mro] #1046590
08/03/11 02:50 PM
08/03/11 02:50 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That is a CONE type SURE GRIP and it's a POS by design ... pass ...
Also there is a picture of the different type of SURE GRIPS in the tech archive .
edit ... i see i was treed ...
Re: posi confusion [Re: JohnRR] #1046591
08/03/11 02:57 PM
08/03/11 02:57 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
the cone style may not be optimal but it works fine. I have beat on the cone type with 400 h.p. with no problems.
Re: posi confusion [Re: west] #1046592
08/03/11 03:03 PM
08/03/11 03:03 PM
JohnRR Offline
JohnRR  Offline
You could beat it with 2000 hp , that still doesn't change the fact that it's a POS design .
Re: posi confusion [Re: mro] #1046593
08/04/11 08:41 AM
08/04/11 08:41 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
If you know that then you also know that you'll "get your nads cracked" for calling it a posi here (of ALL places).
Don't come in here and immediately do something that you KNOW will pizz people off. That's arrogance.
GIGO
