Re: posi confusion
[Re: drew72]
#1046578
08/03/11 01:05 PM
08/03/11 01:05 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Sure grip is mopar for posi and open is just that open.
I have mechanical Aptitude. I can screw up anything.
Re: posi confusion
[Re: mro]
#1046579
08/03/11 01:07 PM
08/03/11 01:07 PM
Posts: 1,564 St. Clair Shores, Michigan
bigsbigelow
"Posi-Trac" is actually a GM term used for GM's limited slip differential. Chrysler called their limited slip differentials the "Sure Grip". Generally speaking, a "Posi" is a limited slip differential.
EDIT: I got treed, big time.
Re: posi confusion
[Re: bigsbigelow]
#1046580
08/03/11 01:10 PM
08/03/11 01:10 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
Guy - I know its called sure grip - to humanity its a posi. I don't come on here to have my nads cracked. I come on here for help when I need it and I HELP ALOT OF PEOPLE HERE IN RETURN SO COOL YOUR JETS GM BOY.
68 Satellite Wagon and a few other ones
Re: posi confusion
[Re: mro]
#1046582
08/03/11 01:26 PM
08/03/11 01:26 PM
bigsbigelow
If this reply was directed to me:
I meant no disrespect. The question you asked is a beginners question, plain and simple. I figured I would help you out and explain the correct terminology. I don't crack nads, I try and enlighten when I can. Sorry you were offended.
Re: posi confusion
[Re: mro]
#1046583
08/03/11 01:32 PM
08/03/11 01:32 PM
Posts: 492 Kansas
BEINGmeISaCRIME
Kansas
I can't remember which was which - posi unit what was the open ? closed? pics? im confused
An "open" differential is what you might also have seen called the one wheel wonder
Re: posi confusion
[Re: BEINGmeISaCRIME]
#1046584
08/03/11 02:16 PM
08/03/11 02:16 PM
mro
Lynch Road
Sorry - crappy day - I don't remember like I used to - the unit has the window through the casing and I can see the clutch springs - thats the closed right?
Re: posi confusion
#1046585
08/03/11 02:17 PM
08/03/11 02:17 PM
mro
Lynch Road
And by the way - it was directed at DREW.
Re: posi confusion
[Re: mro]
#1046586
08/03/11 02:20 PM
08/03/11 02:20 PM
bigsbigelow
Yes. More specifically, it is the cone type Sure Grip.
Re: posi confusion
[Re: mro]
#1046590
08/03/11 02:50 PM
08/03/11 02:50 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
That is a CONE type SURE GRIP and it's a POS by design ... pass ...
Also there is a picture of the different type of SURE GRIPS in the tech archive .
edit ... i see i was treed ...
Re: posi confusion
[Re: JohnRR]
#1046591
08/03/11 02:57 PM
08/03/11 02:57 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
the cone style may not be optimal but it works fine. I have beat on the cone type with 400 h.p. with no problems.
Re: posi confusion
[Re: west]
#1046592
08/03/11 03:03 PM
08/03/11 03:03 PM
JohnRR
You could beat it with 2000 hp , that still doesn't change the fact that it's a POS design .
Re: posi confusion
[Re: mro]
#1046593
08/04/11 08:41 AM
08/04/11 08:41 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
If you know that then you also know that you'll "get your nads cracked" for calling it a posi here (of ALL places). Don't come in here and immediately do something that you KNOW will pizz people off. That's arrogance. GIGO
