mp gold box no spark #1046099
08/02/11 08:55 PM
08/02/11 08:55 PM
New Hampshire
n_bogie1984 Offline OP
New Hampshire
so i decided to switch out my old chrome box for a gold one, according all papers iveseen wireing is same, wit a .70 ohm ballast and a blaster 2 coil, coil is yr old and had twoballasts and tried them both, the box came from summit in a mopar box no paprs what so ever. and the center screw didnt seem to grab like it was stripped. from wht i read that combo will work just not have the high output as with the mp coil and 1/4 ohm. would you think box is no good and return or did i miss something?
Re: mp gold box no spark [Re: n_bogie1984] #1046100
08/02/11 10:11 PM
08/02/11 10:11 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Make sure the box was grounded to the car. Since you say the screw hole for the harness seemed stripped out, you may have got a faulty box someone else returned !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: mp gold box no spark [Re: n_bogie1984] #1046101
08/03/11 01:18 PM
08/03/11 01:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Sounds like a bad box.
If it was mine I'd either leave the chrome on it, or switch to msd.
Rich H.
Esse Quam Videri
Re: mp gold box no spark [Re: n_bogie1984] #1046102
08/03/11 01:58 PM
08/03/11 01:58 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
a little bit off topic
you are the first guy what I know trying a gold box. Is stated just for Race purpouse.
is there someone else running or trying to run a gold box around ?
Re: mp gold box no spark [Re: NachoRT74] #1046103
08/03/11 05:27 PM
08/03/11 05:27 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the gold box is for race applications only. it will over-heat and burn up with constant low rpms. it is also a multi-spark and requires a different wiring harness which is why you can't get it screwed in right.
Re: mp gold box no spark [Re: mikemee1331] #1046104
08/03/11 07:42 PM
08/03/11 07:42 PM
New Hampshire
New Hampshire
everything i have seen says it same plug and harness
Re: mp gold box no spark [Re: n_bogie1984] #1046105
08/03/11 08:36 PM
08/03/11 08:36 PM
BA, OK
O
orangedustya Offline
O
BA, OK
I have had my gold box on a 68 Dart, a 73 Duster, and now on a 74 Dart Sport. There is no differece in wiring from a stock box to any other box whether its orange, chrome, or gold. I also ran the gold on the street with no problem. When you mount it make sure it is grounded and I always use washers to space it off firewall or fender to help backside from retaining heat.
Brad
Re: mp gold box no spark [Re: orangedustya] #1046106
08/03/11 08:54 PM
08/03/11 08:54 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
from what i read it depends on whether it's a 4 pin or 5 pin harness.
Re: mp gold box no spark [Re: mikemee1331] #1046107
08/03/11 10:17 PM
08/03/11 10:17 PM
BA, OK
O
O
BA, OK
The box will have 4 pins and the harness has 5 pin connector. At least thats the way mine is. I don't know what the 5th one on the harness is for but I've had stock, orange, and gold on it and they all ran fine.
Brad
