Re: mp gold box no spark
[Re: n_bogie1984]
#1046100
08/02/11 10:11 PM
08/02/11 10:11 PM
Posts: 1,045 Slidell, La.
doctor_mopar
Slidell, La.
Make sure the box was grounded to the car. Since you say the screw hole for the harness seemed stripped out, you may have got a faulty box someone else returned !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: n_bogie1984]
#1046101
08/03/11 01:18 PM
08/03/11 01:18 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Sounds like a bad box.
If it was mine I'd either leave the chrome on it, or switch to msd.
Rich H.
Esse Quam Videri
[Re: n_bogie1984]
#1046102
08/03/11 01:58 PM
08/03/11 01:58 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
a little bit off topic
you are the first guy what I know trying a gold box. Is stated just for Race purpouse.
is there someone else running or trying to run a gold box around ?
[Re: NachoRT74]
#1046103
08/03/11 05:27 PM
08/03/11 05:27 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
the gold box is for race applications only. it will over-heat and burn up with constant low rpms. it is also a multi-spark and requires a different wiring harness which is why you can't get it screwed in right.
