Re: used original trunk mat or repop?
[Re: LimeliteAero]
#1045889
08/07/11 11:49 AM
08/07/11 11:49 AM
Posts: 3,683 The Historic Hudson Valley
MONC
the matts trap moisture from leaky trunks....most restored cars wont see enough water to have a moisture issue.
I'm sure that's a part of it, but I have found even those trunks which did not leak still had moisture trapped under the mat.
I am thinking open trunk during hot humid summer day at a show, close the trunk with that new airtight seal and where does all that moist air in the trunk go? It's stays there then cools and the moisture has to go somewhere. It condenses and ends up between the mat and the trunk floor. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: mopars_1]
#1045893
08/08/11 12:32 PM
08/08/11 12:32 PM
I would have to say 68-70 B body (chargers) and then the E bodys.
[Re: ademon]
#1045894
08/08/11 12:47 PM
08/08/11 12:47 PM
Posts: 21,541 N.E. OHIO, USA
A12
N.E. OHIO, USA
69-70 B body, 70-76 A body i would think would sell the best
'68 B-bodies are the same IINM as the '69-'70 B-bodies.....
and what about '68 and '69 A-body Darts seems like there are lots of those out there too?
MikeR
[Re: A12]
#1045896
08/08/11 12:59 PM
08/08/11 12:59 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Material thickness, most patterns weren't just print but actually slightly three dimensional..Fact is even the back side has a slight texture.. The die cut shapes of the repos is generally way off...
[Re: 1_WILD_RT]
#1045897
08/08/11 01:44 PM
08/08/11 01:44 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
man you said it....I just threw a piece of crap repop mat in the R/T and it was actually stamped upside sown, when I flipped the mat it fit pretty good compared to the crappy way it sits now.
[Re: 1_WILD_RT]
#1045898
08/08/11 04:44 PM
08/08/11 04:44 PM
A12
N.E. OHIO, USA
So they were almost a "weave" and not just a printed pattern Did they have something bonded into the mat to reinforce or strengthen it????
[Re: 1_WILD_RT]
#1045901
08/08/11 09:24 PM
08/08/11 09:24 PM
Posts: 712 California
BigDaddy440
California
I'm working on a full resto of a 69.5 Roadrunner. I have the original trunk mat, and I plan to use it even if it's not perfect. It a little damaged in spots but it's all there. Given the extent my car was raced, I'm surprised it wasn't tossed out a some point.
-dan
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
