Re: used original trunk mat or repop? [Re: MONC] #1045887
08/06/11 05:32 PM
08/06/11 05:32 PM
SE Pa.
LimeliteAero Offline
SE Pa.
the matts trap moisture from leaky trunks....most restored cars wont see enough water to have a moisture issue.
Re: used original trunk mat or repop? [Re: LimeliteAero] #1045888
08/06/11 05:56 PM
08/06/11 05:56 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Mine gets washed regularly... But the trunk seal is in place & works as it should... Also the trunk floor actually has paint on it instead of the mist of color the factory applied..... I take my old MCO mat out from time to time & clean underneath it, there's some old water stains but no rust..... Cars been done for fifteen years, next time it needs a trunk floor I probably won't be alive...
Re: used original trunk mat or repop? [Re: LimeliteAero] #1045889
08/07/11 11:49 AM
08/07/11 11:49 AM
The Historic Hudson Valley
MONC Offline
MONC  Offline
I'm sure that's a part of it, but I have found even those trunks which did not leak still had moisture trapped under the mat.
I am thinking open trunk during hot humid summer day at a show, close the trunk with that new airtight seal and where does all that moist air in the trunk go? It's stays there then cools and the moisture has to go somewhere. It condenses and ends up between the mat and the trunk floor.
Re: used original trunk mat or repop? [Re: MONC] #1045890
08/07/11 11:52 AM
08/07/11 11:52 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Original.. Its the only way to go..
Re: used original trunk mat or repop? [Re: HPMike] #1045891
08/07/11 05:31 PM
08/07/11 05:31 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Re: used original trunk mat or repop? [Re: az426john] #1045892
08/07/11 10:35 PM
08/07/11 10:35 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
1971 B-bodies
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: used original trunk mat or repop? [Re: mopars_1] #1045893
08/08/11 12:32 PM
08/08/11 12:32 PM
I would have to say 68-70 B body (chargers) and then the E bodys.
Re: used original trunk mat or repop? [Re: ademon] #1045894
08/08/11 12:47 PM
08/08/11 12:47 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
69-70 B body, 70-76 A body i would think would sell the best
'68 B-bodies are the same IINM as the '69-'70 B-bodies.....
and what about '68 and '69 A-body Darts seems like there are lots of those out there too?
MikeR
Re: used original trunk mat or repop? [Re: A12] #1045895
08/08/11 12:54 PM
08/08/11 12:54 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Now that we have someone interested in maybe making them; What exactly makes the original better than any or most of reproduction trunk mats???????????
MikeR
Re: used original trunk mat or repop? [Re: A12] #1045896
08/08/11 12:59 PM
08/08/11 12:59 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Material thickness, most patterns weren't just print but actually slightly three dimensional..Fact is even the back side has a slight texture.. The die cut shapes of the repos is generally way off...
Re: used original trunk mat or repop? [Re: 1_WILD_RT] #1045897
08/08/11 01:44 PM
08/08/11 01:44 PM
SE Pa.
SE Pa.
man you said it....I just threw a piece of crap repop mat in the R/T and it was actually stamped upside sown, when I flipped the mat it fit pretty good compared to the crappy way it sits now.
Re: used original trunk mat or repop? [Re: 1_WILD_RT] #1045898
08/08/11 04:44 PM
08/08/11 04:44 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
So they were almost a "weave" and not just a printed pattern Did they have something bonded into the mat to reinforce or strengthen it????
Re: used original trunk mat or repop? [Re: A12] #1045899
08/08/11 05:58 PM
08/08/11 05:58 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I have seen so many cars with completely wrong pattern and fitting mats. I think many buyers just don't know what's correct and neither do the sellers? The question is what is the correct fitting mat worth? At $49 each plus shipping, there's not much incentive to the vendor to make improvements in what is available. For 69 BBody cars, ACC makes the closest pattern and fit of any vendor. I can't vouch for other years and models. It still takes me 1.5 hours to retrim the ACC ones to match my original templates. ( I've cut a few for the A12 guys).
Re: used original trunk mat or repop? [Re: A12] #1045900
08/08/11 07:01 PM
08/08/11 07:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not a weave, just a embossed grain/textured pattern & some had a smooth backside but depending on application some had a non-skid sort of crosshatched pattern on the back...
Re: used original trunk mat or repop? [Re: 1_WILD_RT] #1045901
08/08/11 09:24 PM
08/08/11 09:24 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I'm working on a full resto of a 69.5 Roadrunner. I have the original trunk mat, and I plan to use it even if it's not perfect. It a little damaged in spots but it's all there. Given the extent my car was raced, I'm surprised it wasn't tossed out a some point.
-dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
