Re: How to Adjust a LOKAR Kickdown cable.
[Re: west]
#1044830
08/01/11 04:22 PM
08/01/11 04:22 PM
Posts: 643 southern conn
1969gtx
southern conn
It can make a difference ware the cable hooks to carb. The closer to the shaft make cable move slower. so if you need it to shift sooner move closer to shaft. good luck
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: midnite360]
#1044831
08/01/11 07:27 PM
08/01/11 07:27 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You can't adjust out poor design, the Lokar only works if the total travel of the carb lever matches the total travel of the transmission lever....they seldom do. In most cases the transmission lever is too long and a new hole must be drilled closer to the transmission.
Adding a spring to pull the transmission lever forward is another think Lokar omitted but is a must.
[Re: John_Kunkel]
#1044840
08/02/11 05:52 PM
08/02/11 05:52 PM
Posts: 11,081 Berlin, N.J.
abodyjoe
Berlin, N.J.
i find it pretty hard to believe that i just got lucky with all the ones i have installed.
Not necessarily lucky, just willing to accept the way they operate when adjusted according to the instructions. Some folks think a light-throttle 1-2 shift at 35 and a 2-3 shift at 45 is OK.
like i said i have never has issues like you claim to have had with the lokar set up. my car shifts damn nicely when barley on the throttle or when really into the throttle and all the places in between.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: 73swinger]
#1044843
08/03/11 10:20 AM
08/03/11 10:20 AM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
This is EXACTLY what I had to do also.
Got any pics of that?
