How to Adjust a LOKAR Kickdown cable. #1044828
08/01/11 01:41 PM
08/01/11 01:41 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
It take way to long to shift and then doesnt want to go into 3rd... The instructions are kinda lame. Anyhelp would be great!
Re: How to Adjust a LOKAR Kickdown cable. [Re: midnite360] #1044829
08/01/11 03:41 PM
08/01/11 03:41 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
make sure your fluid is full first.
at 15-20 mph the car should shift through all 3 gears and the lever on the trans should be back all the way at full throttle.
Re: How to Adjust a LOKAR Kickdown cable. [Re: west] #1044830
08/01/11 04:22 PM
08/01/11 04:22 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
It can make a difference ware the cable hooks to carb. The closer to the shaft make cable move slower. so if you need it to shift sooner move closer to shaft. good luck
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: How to Adjust a LOKAR Kickdown cable. [Re: midnite360] #1044831
08/01/11 07:27 PM
08/01/11 07:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You can't adjust out poor design, the Lokar only works if the total travel of the carb lever matches the total travel of the transmission lever....they seldom do. In most cases the transmission lever is too long and a new hole must be drilled closer to the transmission.
Adding a spring to pull the transmission lever forward is another think Lokar omitted but is a must.
Re: How to Adjust a LOKAR Kickdown cable. [Re: John_Kunkel] #1044832
08/01/11 09:10 PM
08/01/11 09:10 PM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
I tried for ever and it barely works now. I had to lengthen the carb arm so I could get more pull on the cable. Still fine tuning now, but soon I may give up and get a better cable.
If you are not in love with it, send it back and get the other guys lokar kickdown cable for mopes is just crap.
Re: How to Adjust a LOKAR Kickdown cable. [Re: plazomat] #1044833
08/01/11 10:01 PM
08/01/11 10:01 PM
Goodyear Arizona
Goodyear Arizona
Who makes a better alternative?
Re: How to Adjust a LOKAR Kickdown cable. [Re: midnite360] #1044834
08/01/11 11:08 PM
08/01/11 11:08 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I wouldnt be so prejudiced against it just yet...be patient and let some more with experience chime in.
Lokar Cables are nice pieces. And since when does anything work out of the box on a mopar? ahaha? If there is something, I sure as hell dont know about it!
Re: How to Adjust a LOKAR Kickdown cable. [Re: POS Dakota] #1044835
08/01/11 11:20 PM
08/01/11 11:20 PM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
Im using a lokar cable on a 750 holley and 727/440. I have been swapping around carbs and found there is a sweet spot. Right now it shifts into 2 just fine but third is too long. It is very sensitive when you get close. I will try the spring on the tranny lever. Im not sure if there is one there or not.
Re: How to Adjust a LOKAR Kickdown cable. [Re: midnite360] #1044836
08/01/11 11:28 PM
08/01/11 11:28 PM
IL
71383beep Offline
71383beep  Offline
IL
The Bouchillon kit is WAY better than a lokar. Very good instructions too.
http://www.bouchillonperformance.com/BPEtkdc.asp
'73 GK6 Challenger Rallye - 340 4-Speed
Re: How to Adjust a LOKAR Kickdown cable. [Re: 71383beep] #1044837
08/02/11 05:06 PM
08/02/11 05:06 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Re: How to Adjust a LOKAR Kickdown cable. [Re: midnite360] #1044838
08/02/11 05:37 PM
08/02/11 05:37 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
are you sure its installed correctly? i have installed lokar kickdowns on many cars and have never had any issues with adjusting it. never had to drill extra holes in the trans leaver, never had to install a return spring at the trans. i find it pretty hard to believe that i just got lucky with all the ones i have installed. sounds to me that something isn't correct with the install. did you cut the cable down enough? where do you have it hooked tot he carb??
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: How to Adjust a LOKAR Kickdown cable. [Re: abodyjoe] #1044839
08/02/11 05:46 PM
08/02/11 05:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not necessarily lucky, just willing to accept the way they operate when adjusted according to the instructions. Some folks think a light-throttle 1-2 shift at 35 and a 2-3 shift at 45 is OK.
Re: How to Adjust a LOKAR Kickdown cable. [Re: John_Kunkel] #1044840
08/02/11 05:52 PM
08/02/11 05:52 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
like i said i have never has issues like you claim to have had with the lokar set up. my car shifts damn nicely when barley on the throttle or when really into the throttle and all the places in between.
Re: How to Adjust a LOKAR Kickdown cable. [Re: abodyjoe] #1044841
08/02/11 05:55 PM
08/02/11 05:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I have had no problems using the lokar on a 727 trans and am using the same lokar on my 518 with only having to drill a hole inboard on the trans lever.
Re: How to Adjust a LOKAR Kickdown cable. [Re: John_Kunkel] #1044842
08/03/11 12:08 AM
08/03/11 12:08 AM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
This is EXACTLY what I had to do also.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: How to Adjust a LOKAR Kickdown cable. [Re: 73swinger] #1044843
08/03/11 10:20 AM
08/03/11 10:20 AM
Cambridge, Ontario, Canada
CUDAJAS Offline
CUDAJAS  Offline
Got any pics of that?
Re: How to Adjust a LOKAR Kickdown cable. [Re: CUDAJAS] #1044844
08/03/11 12:28 PM
08/03/11 12:28 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
My Lokar throttle and trans cables function just fine. I found them quite easy to install. Soft low shifts at light throttle, and banging shifts at WOT. I run a TransGo too.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: How to Adjust a LOKAR Kickdown cable. [Re: abodyjoe] #1044845
08/03/11 06:46 PM
08/03/11 06:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Then you DID luck out and had one of the shorter TP levers, the most common TP lever is way too long to properly work with the generic Lokar.
