New 383 will not idle. #1044118
07/31/11 06:53 PM
07/31/11 06:53 PM
pa
greg383 Offline OP
greg383  Offline OP
pa
I just got my new 383 running.Broke in the cam and now when i try to turn the idle down it will not drop below 1800rpm to 2000rpm with out stalling and blowing back through the carb.Then its hard to start back up and will only stay running above 1800.
Re: New 383 will not idle. [Re: greg383] #1044119
07/31/11 06:59 PM
07/31/11 06:59 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
sounds like your timings way retarded, turn the distributor a good amount advance and lock it down
Re: New 383 will not idle. [Re: ademon] #1044120
07/31/11 08:16 PM
07/31/11 08:16 PM
Washington
69440 Offline
69440  Offline
Washington
Sounds like a possible bad vacuum leak.
Re: New 383 will not idle. [Re: 69440] #1044121
07/31/11 09:41 PM
07/31/11 09:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
check the coil side of the ballast. see if it has at least 9 volts.
Coming soon!!!!
Re: New 383 will not idle. [Re: Mr.Yuck] #1044122
08/01/11 03:10 AM
08/01/11 03:10 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
What is your ignition set-up? I had a similar problem with my 440 source ready to run dist. I swapped in a stock points dist and it ran like stock.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: New 383 will not idle. [Re: phantomx] #1044123
08/01/11 09:53 AM
08/01/11 09:53 AM
pa
greg383 Offline OP
greg383  Offline OP
pa
I have the 440 source/pro comp distributor.Ive tried turning it to change timing but it doesnt matter where it is,still does same thing.Do I need to hook both wires to coil and key on power to power of coil.I have a MSD Blaster 2 coil.
Re: New 383 will not idle. [Re: greg383] #1044124
08/01/11 10:32 AM
08/01/11 10:32 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm guessing you followed the directions give. Did you check the ballast yet? I had the same issue a few months ago. car would start up and run above 1500rpm as soon..and I mean as soon as I dropped the rpm it would shut off. Acted like it was running out of gas. I swapped ECM, Votage reg, cleaned the carbs. Long story short, the ballast went bad. Over to the shelf, new ballast and 2 minutes later problem solved.
Re: New 383 will not idle. [Re: Mr.Yuck] #1044125
08/01/11 10:43 AM
08/01/11 10:43 AM
pa
greg383 Offline OP
greg383  Offline OP
pa
I followed the directions that i got from pro-comp.Ground side from distributor to ground side of coil.Running a msd blaster 2 coil.12v direct to positive side of distributor.Resistor side of resistor to pos.side of coil.Pro comp said that the dist needed 12v with out a resistor.When it does shut off it coughs up through the carb,its like it just shuts off at lower than 1800 rpm.
Re: New 383 will not idle. [Re: greg383] #1044126
08/01/11 10:56 AM
08/01/11 10:56 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Vacuum leak?
Coming soon!!!!
Re: New 383 will not idle. [Re: Mr.Yuck] #1044127
08/01/11 11:02 AM
08/01/11 11:02 AM
pa
greg383 Offline OP
greg383  Offline OP
pa
Im pretty sure i dont have any,sprayed cleaner all over the place while it is running and got no change,it would have to be a pretty huge vacuum leak,at least thats what i thought too.
Re: New 383 will not idle. [Re: greg383] #1044128
08/01/11 11:19 AM
08/01/11 11:19 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Make sure the secondaries are fully closed too.
Re: New 383 will not idle. [Re: buildanother] #1044129
08/01/11 11:30 AM
08/01/11 11:30 AM
pa
greg383 Offline OP
greg383  Offline OP
pa
I will check that,its a new Edelbrock 750,im used to holleys so still learning about this one.
Re: New 383 will not idle. [Re: greg383] #1044130
08/01/11 12:22 PM
08/01/11 12:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
nevermind...
(go get a holley)
Re: New 383 will not idle. [Re: Mr.Yuck] #1044131
08/01/11 12:36 PM
08/01/11 12:36 PM
pa
greg383 Offline OP
greg383  Offline OP
pa
Thats what im starting to think as well.
Re: New 383 will not idle. [Re: Mr.Yuck] #1044132
08/01/11 12:47 PM
08/01/11 12:47 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
nevermind...
(go get a holley)
This is where I will agree wit hyou , the performer 750 is a piece of junk , but it's not the main reason behind his idle problem.
I thought with that CCJ ready to run you have to ditch the ballast resistor ?
Re: New 383 will not idle. [Re: greg383] #1044133
08/01/11 12:57 PM
08/01/11 12:57 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
did you re-check your firing order??
Is the cam degreed in?
Re: New 383 will not idle. [Re: greg383] #1044134
08/01/11 02:30 PM
08/01/11 02:30 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
What ignition box are you running?
If ProComp....
Chuck it in the trash, their distributor is OK (cloned after MSD) but the box is cheaply designed and not reliable. We just pulled one out of a friend's 65 Sat and put in an MSD starts/runs fine now..
Just my $0.02..
Re: New 383 will not idle. [Re: Sinitro] #1044135
08/02/11 02:10 AM
08/02/11 02:10 AM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
If you have access to one, try plopping in a stock dist and see if your troubles go away. That sounds just like what mine was doing.
Travis..
