Re: New 383 will not idle.
[Re: Mr.Yuck]
#1044122
08/01/11 03:10 AM
08/01/11 03:10 AM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
What is your ignition set-up? I had a similar problem with my 440 source ready to run dist. I swapped in a stock points dist and it ran like stock. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: greg383]
#1044124
08/01/11 10:32 AM
08/01/11 10:32 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I have the 440 source/pro comp distributor.Ive tried turning it to change timing but it doesnt matter where it is,still does same thing.Do I need to hook both wires to coil and key on power to power of coil.I have a MSD Blaster 2 coil.
I'm guessing you followed the directions give. Did you check the ballast yet? I had the same issue a few months ago. car would start up and run above 1500rpm as soon..and I mean as soon as I dropped the rpm it would shut off. Acted like it was running out of gas. I swapped ECM, Votage reg, cleaned the carbs. Long story short, the ballast went bad. Over to the shelf, new ballast and 2 minutes later problem solved.
[Re: greg383]
#1044130
08/01/11 12:22 PM
08/01/11 12:22 PM
Mr.Yuck
Brookeville, Md
I will check that,its a new Edelbrock 750,im used to holleys so still learning about this one.
nevermind... (go get a holley)
[Re: Mr.Yuck]
#1044132
08/01/11 12:47 PM
08/01/11 12:47 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
This is where I will agree wit hyou , the performer 750 is a piece of junk , but it's not the main reason behind his idle problem.
I thought with that CCJ ready to run you have to ditch the ballast resistor ?
[Re: greg383]
#1044134
08/01/11 02:30 PM
08/01/11 02:30 PM
Posts: 5,447 So Cal
Sinitro
So Cal
What ignition box are you running? If ProComp.... Chuck it in the trash, their distributor is OK (cloned after MSD) but the box is cheaply designed and not reliable. We just pulled one out of a friend's 65 Sat and put in an MSD starts/runs fine now..
Just my $0.02..
[Re: Sinitro]
#1044135
08/02/11 02:10 AM
08/02/11 02:10 AM
phantomx
W. Sacto CA. USA
If you have access to one, try plopping in a stock dist and see if your troubles go away. That sounds just like what mine was doing. Travis..
