JOSS ENGINES 468ci. W2 Small block. What will it make??
#1043510
07/30/11 10:42 PM
07/30/11 10:42 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Just did the break in on the engine, and it is currently on the pump ready to make some pulls! Any guesses what it will make? The engine dyno is a manual run Stuska water brake. 468ci. R3 tall deck 48 degree siamezed block (673AD) 4.250" stroke 4.185" bore 6.300" rod 1050 dominator 1" plastic 4 hole spacer 2" 4500 to 4150 adapter Victor W2 intake Econo W2's Ported by Brian at IMM Engine & Dyno 52cc chambers 13.3:1 compression 1.7:1 T&D Rockers 2.02" intake / 1.60" exhaust Comp solid roller 277/284 @ .050" .748"/.714" lift 110 LSA with 2 degree advance built in. Hedman Huslers 1-7/8" primaries 3.5" collector Let me know if I missed anything. I am kind of in a hurry. Going to go yank some pulls now! -Kenny
Re: JOSS ENGINES 468ci. W2 Small block. What will it make??
[Re: StrokerAspen]
#1043511
07/30/11 10:51 PM
07/30/11 10:51 PM
quick77rt
Parts Problem
Parts Problem
Nice build stroker, I feel the heads wont support that many cubic inches to max it out. If you got 320 out of the heads 640hp Id hope alot more since 600 plus can be done with alot less. Our 408/410s make 1.5 per easy, do you think near 700hp is possible?? Whats your target hp???? Good luck on the pump and let us know. I know the w2-s can be very surprising power wise. Let me know if I missed anything. I am kind of in a hurry.....Um carb would be nice
[Re: quick77rt ]
#1043512
07/30/11 11:14 PM
07/30/11 11:14 PM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
[Re: StrokerAspen]
#1043515
07/30/11 11:36 PM
07/30/11 11:36 PM
Posts: 6,295 U.S.
moparniac
U.S.
468CI and w2's ? ill guess 650HP for the heck of it!
Mopar Performance
[Re: MIKES_DUSTER]
#1043516
07/30/11 11:42 PM
07/30/11 11:42 PM
StrokerAspen
Alberta Canada
Id say around 400hp if your LUCKY!!!!
Haha, thanks Mike! Guess again, it made more than that on a half pull on the primaries, with apparently 7 cylinder lol.
[Re: topbrent]
#1043520
07/31/11 12:41 AM
07/31/11 12:41 AM
StrokerAspen
Alberta Canada
Should be fun in the new car!
Oh yes! A little lighter than the Aspen. It will go in the aspen for now.
[Re: 72demon416]
#1043522
07/31/11 02:32 AM
07/31/11 02:32 AM
StrokerAspen
Alberta Canada
You didn't say what intake but I'll say 660 just for giggles.
It's there too... W2 Victor intake.
[Re: StrokerAspen]
#1043524
07/31/11 04:11 AM
07/31/11 04:11 AM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
DOH, my bad
