Page 1 of 3 1 2 3
JOSS ENGINES 468ci. W2 Small block. What will it make?? #1043510
07/30/11 10:42 PM
07/30/11 10:42 PM
Alberta Canada
StrokerAspen Offline OP
Alberta Canada
Just did the break in on the engine, and it is currently on the pump ready to make some pulls! Any guesses what it will make? The engine dyno is a manual run Stuska water brake.
468ci.
R3 tall deck 48 degree siamezed block (673AD)
4.250" stroke
4.185" bore
6.300" rod
1050 dominator
1" plastic 4 hole spacer
2" 4500 to 4150 adapter
Victor W2 intake
Econo W2's Ported by Brian at IMM Engine & Dyno
52cc chambers
13.3:1 compression
1.7:1 T&D Rockers
2.02" intake / 1.60" exhaust
Comp solid roller
277/284 @ .050"
.748"/.714" lift
110 LSA with 2 degree advance built in.
Hedman Huslers
1-7/8" primaries
3.5" collector
Let me know if I missed anything. I am kind of in a hurry. Going to go yank some pulls now!
-Kenny
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043511
07/30/11 10:51 PM
07/30/11 10:51 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Nice build stroker, I feel the heads wont support that many cubic inches to max it out.
If you got 320 out of the heads 640hp Id hope alot more since 600 plus can be done with alot less.
Our 408/410s make 1.5 per easy, do you think near 700hp is possible??
Whats your target hp????
Good luck on the pump and let us know. I know the w2-s can be very surprising power wise.
Let me know if I missed anything. I am kind of in a hurry.....Um carb would be nice
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: quick77rt ] #1043512
07/30/11 11:14 PM
07/30/11 11:14 PM
Guitar Jones Offline
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: quick77rt ] #1043513
07/30/11 11:33 PM
07/30/11 11:33 PM
Alberta Canada
Alberta Canada
The carb is in there. It's a 1050 dominator.
Just hit a speed bump on the first pull. Had a intake push rod fail. The ball came off and made a mess of an adjuster and the rocker. I will phone Smith Brothers and get a few extra, and hopefully T&D can get me another adjuster.
Any way, keep the guesses coming.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043514
07/30/11 11:35 PM
07/30/11 11:35 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Id say around 400hp if your LUCKY!!!!
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043515
07/30/11 11:36 PM
07/30/11 11:36 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
468CI and w2's ? ill guess 650HP for the heck of it!
Mopar Performance
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: MIKES_DUSTER] #1043516
07/30/11 11:42 PM
07/30/11 11:42 PM
Alberta Canada
Alberta Canada
Haha, thanks Mike! Guess again, it made more than that on a half pull on the primaries, with apparently 7 cylinder lol.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043517
07/30/11 11:55 PM
07/30/11 11:55 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Dang stroker, you and your pushrods...that blows. But you will get it right and singing like a bee.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043518
07/31/11 12:16 AM
07/31/11 12:16 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Should be fun in the new car!
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043519
07/31/11 12:30 AM
07/31/11 12:30 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I'll guess 622 HP
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: topbrent] #1043520
07/31/11 12:41 AM
07/31/11 12:41 AM
Alberta Canada
Alberta Canada
Oh yes! A little lighter than the Aspen. It will go in the aspen for now.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: ScottSmith_Harms] #1043521
07/31/11 01:25 AM
07/31/11 01:25 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
You didn't say what intake but I'll say 660 just for giggles.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: 72demon416] #1043522
07/31/11 02:32 AM
07/31/11 02:32 AM
Alberta Canada
Alberta Canada
It's there too... W2 Victor intake.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043523
07/31/11 02:41 AM
07/31/11 02:41 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
672
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043524
07/31/11 04:11 AM
07/31/11 04:11 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
DOH, my bad
Re: JOSS ENGINES 468ci. W2 Small block. What will it ma [Re: 72demon416] #1043525
07/31/11 04:27 AM
07/31/11 04:27 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
665
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043526
07/31/11 05:01 AM
07/31/11 05:01 AM
Goat Rodeo
drago Offline
drago  Offline
Goat Rodeo
It'll make 468.5 whorepower. dang it.
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: drago] #1043527
07/31/11 08:45 AM
07/31/11 08:45 AM
gregsdart Offline
gregsdart  Offline
710 hp
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: gregsdart] #1043528
07/31/11 09:21 AM
07/31/11 09:21 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
725
Re: JOSS ENGINES 468ci. W2 Small block. What will it make?? [Re: StrokerAspen] #1043529
07/31/11 10:30 AM
07/31/11 10:30 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
It better make more Hp than my Hemi, cause I am pretty sure it cost more....
Page 1 of 3 1 2 3
