A/C clutch assembly R+R #104245
08/13/08 12:38 PM
08/13/08 12:38 PM
Gulf Coast of Florida
Russ Offline OP
super gas
Russ  Offline OP
super gas
got an 86 Aries with the single pulley rotary compressor,how hard Is It to remove and replace the clutch/pulley assy.?
thanks
2001 Durango 5.9 Magnum 99 Durango 5.9 Magnum Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9 WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me. GO BUCKS!!!! Go GATORS!!!!
Re: A/C clutch assembly R+R [Re: Russ] #104246
08/13/08 12:46 PM
08/13/08 12:46 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I think it's just a matter of removing the nut in the center then pull off the pulley. You won't lose any freon because you don't open the system. You should be able to rent or borrow a puller from a good parts store if you need it.
Re: A/C clutch assembly R+R [Re: stumpy] #104247
08/13/08 12:51 PM
08/13/08 12:51 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
i thought so too,so I have a junk one,took off the center nut,and tried to pull It off with no success
Re: A/C clutch assembly R+R [Re: Russ] #104248
08/13/08 01:04 PM
08/13/08 01:04 PM
Hummelstown, PA
AINTNRT Offline
AINTNRT  Offline
Hummelstown, PA
You're gonna have to pry the top plate off with a screwdriver, two would work better. Once the top plate is off there is a snapring underneath that needs to be removed so the pulley can be removed.with the pulley removed there is another snapring that holds the magnetic field to the compressor.
Re: A/C clutch assembly R+R [Re: AINTNRT] #104249
08/13/08 09:27 PM
08/13/08 09:27 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
Taking It to a local shop,getting It done for $100.00,thanks for all the Info
