A/C clutch assembly R+R
#104245
08/13/08 12:38 PM
08/13/08 12:38 PM
Posts: 3,753 Gulf Coast of Florida
Russ
super gas
super gas
got an 86 Aries with the single pulley rotary compressor,how hard Is It to remove and replace the clutch/pulley assy.?
thanks
2001 Durango 5.9 Magnum
99 Durango 5.9 Magnum
Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9
WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me.
GO BUCKS!!!!
Go GATORS!!!!
Re: A/C clutch assembly R+R
[Re: Russ]
#104246
08/13/08 12:46 PM
08/13/08 12:46 PM
Posts: 32,943 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
I think it's just a matter of removing the nut in the center then pull off the pulley. You won't lose any freon because you don't open the system. You should be able to rent or borrow a puller from a good parts store if you need it.
[Re: stumpy]
#104247
08/13/08 12:51 PM
08/13/08 12:51 PM
Russ
super gas
super gas
i thought so too,so I have a junk one,took off the center nut,and tried to pull It off with no success
GO BUCKS!!!!
Go GATORS!!!!
