Best ignition system for the street #1042378
07/28/11 10:48 PM
07/28/11 10:48 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hello! Putting the finshing touches on my 512 build for my Challenger. Mostly street, maybe couple trips down the 1/4. Some engine info: 440 stroked to 512, 440Source kit, OOTB Indy EZ's, 511 lift Comp, 10.5-1 comp, NGK plugs, FireCore wires, stock 6pak set-up. I'm using the Mopar elect dizzy, orange box, 4 wire ballast. Just wondering if this ignition is the best? I've read most use the MSD style. I've put a lot of $$ in the engine, and want the best ignition system too. What's the thoughts? Take care! Jeff
Re: Best ignition system for the street [Re: 1969RR] #1042379
07/28/11 10:49 PM
07/28/11 10:49 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I hear good things about the ICE stuff.
Re: Best ignition system for the street [Re: jim sciortino] #1042380
07/28/11 10:55 PM
07/28/11 10:55 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hello, Can you tell me more? Never heard of them. Got any info or web site? Thanks, Jeff
Re: Best ignition system for the street [Re: 1969RR] #1042381
07/28/11 11:18 PM
07/28/11 11:18 PM
IN
ahy Offline
ahy  Offline
IN
The MSD 6 series is hard to beat for a street/strip build. Nothing basically wrong with the MP setup except QC on the boxes seems questionable. The multi strike on the MSD can help starting and low RPM operation.
Re: Best ignition system for the street [Re: 1969RR] #1042382
07/28/11 11:22 PM
07/28/11 11:22 PM
Trumbull,CT.
Trumbull,CT.
They are an Australian company.
www.iceignition.com
Re: Best ignition system for the street [Re: 1969RR] #1042383
07/29/11 12:51 AM
07/29/11 12:51 AM
Cab_Burge Online work
Cab_Burge  Online Work
The Orange Mopar ECU has a built in RPM limiter in it, not good if your planning on running above 6000 RPM If you want the best then look hard at the MSD digital boxes and coils
Re: Best ignition system for the street [Re: Cab_Burge] #1042384
07/29/11 02:12 AM
07/29/11 02:12 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best ignition system for the street [Re: BloFish] #1042385
07/29/11 03:46 AM
07/29/11 03:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also agree but with that said I have the MP orange ECU on my 63 and I have run it to 6500 with no problems. In fact when we had this same box on my sons Dart he had his 400 to 6800 with no problems at all. It works fine for me and his Dart ran no faster when he took of the orange box and went to MSD. Its working good but I do plan to go to MSD down the road. Also the orange box only needs a 2 wire ballast as it should be a 4 pin box. Ron
Re: Best ignition system for the street [Re: 383man] #1042386
07/29/11 04:36 AM
07/29/11 04:36 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Best for street/strip muscle : FBO HR688D kit
http://4secondsflat.com/Ignition.html
Everything is tested and you are sure what you get not like some "three letters" brand stuff
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: Best ignition system for the street [Re: 1969RR] #1042387
07/29/11 08:47 AM
07/29/11 08:47 AM
Mountains of NM
65superstock Offline
Mountains of NM
All three of my cars have the MSD digital 6 boxes. Rock solid for years now. Plus you get built-in rev limiters and since all of my vehicles have manual transmissions, that comes in handy!!
-Jason
Re: Best ignition system for the street [Re: 1969RR] #1042388
07/29/11 08:59 AM
07/29/11 08:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll run a MSD 7-al on my Rampage(street/strip) with
a modified stock dist
Re: Best ignition system for the street [Re: 1969RR] #1042389
07/29/11 09:18 AM
07/29/11 09:18 AM
an8sec70cuda Offline
MSD 6AL here. Running them on 3 different cars.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best ignition system for the street [Re: an8sec70cuda] #1042390
07/29/11 09:39 AM
07/29/11 09:39 AM
central ohio
N
nss guy Online happy
nss guy  Online Happy
N
central ohio
for a simple quick setup and stock look the Pertronix is hard to beat. I ran one for several years with no problems finally switched to msd 6al and no performance difference.
I carry the pertronix setup now for a backup if the msd fails, quick to hook up only 1 wire.
Re: Best ignition system for the street [Re: nss guy] #1042391
07/29/11 11:23 AM
07/29/11 11:23 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I ran the 340, w/orange ECU, to 6700 several times in my 69 GTS.
The MSD 6AL still fired my 383 in my boat when it was literally being showered with water while in a "limp home mode" to the dock.
The multiple spark discharge is only effective below 3000 rpms or so.
Either are very reliable systems as far as I'm concerned. The MSD being better.
Re: Best ignition system for the street [Re: 1969RR] #1042392
07/29/11 04:11 PM
07/29/11 04:11 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I like the original FBO A688 system, and it has the capability to LOOK stock if that's an issue...?
I like the OLDER orange boxes, but the newer orange boxes scare me so much I would toss a chrome box on just to be safe. I've had a half dozen NEWER orange boxes fail, would not hot restart, and since then EVERYTHING I own has a chrome box on it, even my motorhome.
I went with an FBO A688 on my Jensen, so far it has been flawless, I'm truly impressed.
I'm building a 67 Charger street/strip car and looking at the new FBO system that doesn't require a ballast.
Anybody here ran the new FBO system yet??
CrAzYMoPaRGuY
Re: Best ignition system for the street [Re: MR_P_BODY] #1042393
07/29/11 04:28 PM
07/29/11 04:28 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Same setup here.
Re: Best ignition system for the street [Re: Harley] #1042394
07/29/11 05:14 PM
07/29/11 05:14 PM
Anderson, IN
1969RR Offline OP
1969RR  Offline OP
Anderson, IN
Hey Guy's! Thanks for all the input! I've been on the FBO site looking at their ignitions. They do look nice. I'd like to stay stock looking if poss. I'm just having issues with extended cranking, hi RPM "skip". Everything else is new (fuel, engine, etc) so I'm leaning toward ignition. I want to get away from the orange box and ballast resistor. Thanks again everyone! Jeff
Re: Best ignition system for the street [Re: 1969RR] #1042395
07/29/11 05:21 PM
07/29/11 05:21 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
My LIKEY that FBO deal. Had no idea but it seems like a "best of all worlds" box.
Well, except the lack of a rev-limiter, but it looks as though that's coming in Oct.
Re: Best ignition system for the street [Re: 1969RR] #1042396
07/29/11 05:28 PM
07/29/11 05:28 PM
Canada
Canada
The original FBO A688 setup DOES look stock, and mine works flawlessly, I've had it on for over a year and beat my car almost daily.
I'm not sure if the original system is still for sale though??!?
If it was, I would get one for my Charger I'm doing...
CrAzYMoPaRGuY
Re: Best ignition system for the street [Re: 1969RR] #1042397
07/29/11 06:26 PM
07/29/11 06:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To be honest I would use the chrome box... if you
were to break on the road you can put a stock box in
its place to get you home... I dont know what all
you can buy at the local parts store when it comes
to all the other ignitions but I can get some MSD
stuff local
