440 rebuild and dyno #1042191
07/28/11 03:18 PM
07/28/11 03:18 PM
Clarkston, MI
wldgtx Offline OP
wldgtx  Offline OP
Clarkston, MI
Okay, this post is both a "does this sound right" and a "would you change anything else" post.
I have a rebuilt 440 fresh
10:1
509 cam
.10 under forged crank
906 heads (all the standard upgrades)
headers
stock intake
Holley 750
The dyno pulled 503hp and 484tq
Needless to say I was very happy with these numbers, my only question is would you change the intake for an RPM or save the money and leave it alone since it is obviously making good power?
Thanks,
Re: 440 rebuild and dyno [Re: wldgtx] #1042192
07/28/11 03:26 PM
07/28/11 03:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
looks about right to me, now go post this is the race section "$$for$$ post or BB vs SB. Had a dude tell me 500 using staock parts wasn't possible.
Now go run the snot out of it.
Coming soon!!!!
Re: 440 rebuild and dyno [Re: Mr.Yuck] #1042193
07/28/11 03:28 PM
07/28/11 03:28 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
P.S. yes change the intake. You could save some cash by buying a used SD or like. Probably pick up some HP as well. What covert and gears?
Re: 440 rebuild and dyno [Re: Mr.Yuck] #1042194
07/28/11 03:31 PM
07/28/11 03:31 PM
Clarkston, MI
wldgtx Offline OP
wldgtx  Offline OP
Clarkston, MI
4 speed and 3.54 gears
Re: 440 rebuild and dyno [Re: Mr.Yuck] #1042195
07/28/11 03:32 PM
07/28/11 03:32 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Wow I'm surprised you made over 500 with a stock intake. Did you do any port work?
Re: 440 rebuild and dyno [Re: wldgtx] #1042196
07/28/11 03:33 PM
07/28/11 03:33 PM
top-o-the world
RAMIT Offline
RAMIT  Offline
top-o-the world
yea after market intake and slap a demon double pumper on her with a good ignition and watch her scream
Re: 440 rebuild and dyno [Re: wldgtx] #1042197
07/28/11 03:36 PM
07/28/11 03:36 PM
Indiana, United Staes, Vevay
LikarockCrusher Offline
Well, changing the intake is worth around 25 hp I think I'd stay stock. That kind of hp #s and a stock 4bl intake can fool alot of people. Sounds fun fun fun too me.
Re: 440 rebuild and dyno [Re: GTX MATT] #1042198
07/28/11 03:37 PM
07/28/11 03:37 PM
Clarkston, MI
wldgtx Offline OP
wldgtx  Offline OP
Clarkston, MI
I know. It was not my intake, but it was stock, I cannot say that it was not modified or not.
Re: 440 rebuild and dyno [Re: wldgtx] #1042199
07/28/11 03:39 PM
07/28/11 03:39 PM
CT
CT
Sorry I should have clarified, I meant to the heads haha.
Re: 440 rebuild and dyno [Re: Mr.Yuck] #1042200
07/28/11 03:46 PM
07/28/11 03:46 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I was that dude - and if you think that the 509 cam made 125 more horses then a stock 440 +4 ( 375 horse ) .... well I cant wait to see what it runs at the track.. imagine if he put a cam from the 1990's in there???
Not all dyno's read the same number
The the OP - Nice build, but I bet if it goes on a different dyno it reads a different number. Have fun with your motor and good luck.
Re: 440 rebuild and dyno [Re: DJVCuda] #1042201
07/28/11 04:59 PM
07/28/11 04:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I know man, just goofing around ya know. I'm guessing he might have more compression than he thinks with those #'s...maybe they are flip flopped? 504 torque and 484 HP?
Re: 440 rebuild and dyno [Re: Mr.Yuck] #1042202
07/28/11 05:03 PM
07/28/11 05:03 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
I had the same combo except I used a Holley Street Dominator intake. Ran 12.2s all day in my 70 bee. Great cheap combo.
Re: 440 rebuild and dyno [Re: wldgtx] #1042203
07/28/11 05:25 PM
07/28/11 05:25 PM
Cheswick, Pennsylvania U.S.A.
JRod01 Offline
JRod01  Offline
You're definitely doing something right. I have a very similar rebuild and used Indy Heads/intake and the dyno read: 493 HP 518 ft/lb of torque. You did a GREAT JOB!!
Re: 440 rebuild and dyno [Re: DJVCuda] #1042204
07/28/11 05:31 PM
07/28/11 05:31 PM
Clarkston, MI
wldgtx Offline OP
wldgtx  Offline OP
Clarkston, MI
HA... I remember you from Carlisle 2006. I loved you Barracuda!
I hung out with the boys from the Coronet Registry.
Anyway, someone brought up a great point... the compression is likely higher than anticipated since the heads were milled to ensure clean deck. Not that raises it a lot but every bit changes compression.
Again I am no expert, just talking it through.
Re: 440 rebuild and dyno [Re: wldgtx] #1042205
07/28/11 06:02 PM
07/28/11 06:02 PM
Plymouth, MI
HotRod20 Offline
HotRod20  Offline
Plymouth, MI
I too did a similar rebuild in a 67 Coronet R/T.509/292 purple shaft, 3200 converter,3.91 gears,manual shift auto,TM7 intake,750 Holley dbl pumper,ported iron heads using the mopar performance templates,clutch fan,solid motor mts.Hooker super comp headers 1 3/4 tubes,& S/S springs.
Low 12's thru Walker Race Magnum mufflers that dumped in front of the axle. I ran Milan Dragway all day long on street radials that I couldn't hook.Wish I would have uncorked the pipes, and put on a set of slicks!! yahoooo!! Loved the combo.I am planning on doing another.Fast machine & cheap money. Enjoy! HR20.
Re: 440 rebuild and dyno [Re: wldgtx] #1042206
07/28/11 06:07 PM
07/28/11 06:07 PM
The strange thing is the tq not hitting the 500 mark before the hp did.
Re: 440 rebuild and dyno [Re: wldgtx] #1042207
07/28/11 06:08 PM
07/28/11 06:08 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
That combo is what i tell everyone to build for a true milder 440 screamer, Its old school & tried & true, remember back in the day when the Chargers/Coronets/RRs with 440s were tearing up the streets, that was the combo, but they ran a SD & 850dp., 3800 converter & 3.91/4.10 gears.
Buddy of mine had a 68 Charger with the old shool 446 & mildly ported 906 heads, ran 3.23 gears & a 3000 stall, the engine was set up to run a 38-4200 stall & 4.10 gears, he never installed them, Car ran 12.3s @ 109 with a set of slicks & un-corked exhaust on its 1st. & only pass with no other tuneing.
I'd ditch the stock intake for a SD, keep the 750 if its a DPer for now. If you can bang the gears with stickies, car should run mid 12s all day long if not better.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
