Fan CFM Requirements? #1040131
07/25/11 10:07 PM
07/25/11 10:07 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
I know there are TON of variables,but what is the rule of thumb for CFM of fans to HP its trying to cool?
I.E. 450 HP needs 3,300CFM etc........
May need to get electric fans for my street toy and only want to do it once.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Fan CFM Requirements? [Re: 6bblFLASH] #1040132
07/25/11 10:18 PM
07/25/11 10:18 PM
Virginia
HemiStan Online content
HemiStan  Online Content
Virginia
One of my cars dyno'd at 480 HP at the rear wheels. It has a stock looking copper radiator from US Radiator with a stock shroud and fan. I have driven it about 8,000 miles in the past few years. I have been driving it around in the 100 degree plus heat the last few days for several hours and it has always worked great.
Stan
Re: Fan CFM Requirements? [Re: HemiStan] #1040133
07/25/11 10:55 PM
07/25/11 10:55 PM
N.E. Ohio
N.E. Ohio
That sounds easy enough,but there isn`t room for a stock clutch-fan,only a thin flex-fan.
Re: Fan CFM Requirements? [Re: 6bblFLASH] #1040134
07/26/11 05:29 PM
07/26/11 05:29 PM
N.E. Ohio
N.E. Ohio
Re: Fan CFM Requirements? [Re: 6bblFLASH] #1040135
07/26/11 05:36 PM
07/26/11 05:36 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
DEPENDS on the condition of the motor and the quality of the rad .... PLUS whether you use the fan as a puller(best way) or pusher.
Re: Fan CFM Requirements? [Re: dOOc] #1040136
07/26/11 07:12 PM
07/26/11 07:12 PM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
Want to do it once? Then who cares about a formula for CFM? Buy the highest capacity you can fit.
As far as I know Zirgo has the highest CFM ratings thru out all the size range. You have to determine whether you can/want to fit 12, 14 or 16 inch. Zirgo has a powerful pusher in each size.
http://www.zirgo.com/catalog/
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: Fan CFM Requirements? [Re: 68X426] #1040137
07/27/11 12:58 AM
07/27/11 12:58 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
And don't forget that you need a charging system to support those fans.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Fan CFM Requirements? [Re: HemiStan] #1040138
07/27/11 02:11 AM
07/27/11 02:11 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Would a stock fixed blade fan fit? With a proper shroud they cool better than anything else out there.
Re: Fan CFM Requirements? [Re: DaytonaTurbo] #1040139
07/27/11 08:10 AM
07/27/11 08:10 AM
N.E. Ohio
N.E. Ohio
Gonna try one
Re: Fan CFM Requirements? [Re: 6bblFLASH] #1040140
07/27/11 09:03 AM
07/27/11 09:03 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Copper. Thermal. 180 superstat. Green.
Re: Fan CFM Requirements? [Re: DennisH ] #1040141
07/27/11 09:08 AM
07/27/11 09:08 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Fan CFM Requirements? [Re: DennisH ] #1040142
07/27/11 11:54 PM
07/27/11 11:54 PM
N.E. Ohio
N.E. Ohio
Ok,I`ll bite.
Copper = radiator or penny
Thermal = underwear in Ohio
180 Superstat = Keeps score at the ballgame
Green = is a color
Care to elaborate?
Re: Fan CFM Requirements? [Re: 6bblFLASH] #1040143
07/28/11 02:46 PM
07/28/11 02:46 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Ok,I`ll bite.
Green = is a color
Care to elaborate?
That's his standard answer to any cooling system post he sees. I've waiting for him to snap and start posting that on suspension and interior topics too.
He firmly believes that a copper/brass radiator with green coolant running through a 180 degree susperstat being blown on by a thermal fan is the solution to ANY heating problem to ANY vehicle in the known universe.
Little does he know, that stuff doesn't always cure every problem.
It was NOT an option on my hot rod. Once you modify a car you may not be able to use factory parts.
- Stu Harmon
