Re: r3 with indy heads
[Re: Ian]
#1037067
07/21/11 04:11 AM
07/21/11 04:11 AM
Posts: 6,150 Melbourne , Australia
LA360
What R3 block did you buy Ian? A 9", 9.2" or 9.6" deck height block? I have a list somewhere that has the part numbers and basic specs. Without knowing what deck height Block you have, it will be difficult to recommend a rotating assembly.
Alan Jones
[Re: Ian]
#1037068
07/21/11 01:27 PM
07/21/11 01:27 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
thanks for that ,i had to clearance them az well on my 59 degree ,any thoughts on rods and pistons 430-440 cubic inch ,can i mill the indy intake to fit .
hello mate! i have a 59 deg 440ci sb with indy 360-1's if u look up 440sb in the search forum, u should see a post Ryanj wrote about my motor..he also said how nice and easy push rods worked using a 1.65 rocker (mine r t@d) not indy junk!best a luck mate ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: LA360]
#1037069
07/21/11 01:30 PM
07/21/11 01:30 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
hi al its r3 block p4532907 it was givin to me ex prostock engine it is bare not sure what bore size or deck it has no caps it will cost me 400 freight to my door
[Re: Ian]
#1037071
07/23/11 04:32 AM
07/23/11 04:32 AM
LA360
Did you get it off Graig Geddes by chance? I know he had one at one stage. He had some 60mm core roller cams he was selling cheap also. In the pics you sent me, it looks like it has keyway lifter bores, and they don't look like they are in the standard position. I would measure the spacing to be sure. It should be 1.76", but these Comp and PST guys would move things around. Bore space is going to be around the 4.180"-4.20" mark, with a deck height of around 8.8"-8.9". If you are lucky it's an early engine with 318 mains, otherwise it will have ford 2.25" mains. The oiling for wet sump will require a few galleries to be drilled, and drain backs added to the lifter valley. Is the bottom of the cam tunnel enclosed? ![](http://i86.photobucket.com/albums/k118/W8_LA360/Engines/Downloads_IMG_38081.jpg) ![](http://i86.photobucket.com/albums/k118/W8_LA360/Engines/Downloads_IMG_52651.jpg) ![](http://i86.photobucket.com/albums/k118/W8_LA360/Engines/Downloads_IMG_86661.jpg) I have a NIB Comp Cams 60mm Solid Roller, but I doubt it is going to be suited to your combo. Plus you drive that AP6 of yours abit, it would kill too many sets of valve springs! With any luck Mafo (Ken) chimes in, he has an ex Nickens or Patterson PST engine. Ken is quite helpful.
Alan Jones
[Re: Ian]
#1037073
07/23/11 06:35 AM
07/23/11 06:35 AM
LA360
I didn't know he still had the block, I remember him telling me in an email that he picked up some Chrysler stuff in a deal he'd done on a car, he tried selling the stuff, but surprise surprise, no one wanted it over here. I imagine you are going to change the lifter bore bushings? Check the block for cranks, some of that PST stuff was lightened alot and crack. Craig might know of some billet cranks for one of those things, but you're not going to be getting any more than a 3.75"-3.8" stroke crank into it, the deck height will be too short. Let me know if you need anything, I have a couple of odds and sods left over from the W8 engine I was building before I decided to go with a P7 deal.
Alan Jones
[Re: Ian]
#1037074
07/24/11 07:55 AM
07/24/11 07:55 AM
Ian
Victoria, Australia
i love the sound of your car mate i have t&d 1.6 cnc 245 indy the block is a low deck is yours i will find your build thanks
[Re: LA360]
#1037075
07/25/11 03:18 PM
07/25/11 03:18 PM
Posts: 1,019 Finland
mafo
Finland
I m here, just not every day this time of the year...short summers here ![](/ubbthreads/images/graemlins/biggrin.gif)
If you already have the keyway bushings you better step up and get a set of Jesel or Lsm lifters, I got a like new set for 25% of new price, still expensive but outstanding quality
R3 blocks are usually with 340 mains , I believe R4 s are Ford
For oiling you may go with an external pump, then you don t have to drill anything, easy to prelube and pressure adjustment, you just have to live with that extra belt...
I have 3.55 stroke in mine and everything fits easily, most problems I have had is related to somekind of water leaks, both heads and block ![](/ubbthreads/images/graemlins/laugh2.gif)
good luck to you and I m glad if I can help ![](/ubbthreads/images/graemlins/thumbs.gif)
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#1037076
07/25/11 10:45 PM
07/25/11 10:45 PM
LA360
P5007360AB featured 9.025" nominal deck height, Ford 2.25" mains, a 60mm tunnel, steel 4 bolt caps and 48* lifter bores. Although many were ordered without lifter bores. How is the winter over there Ken? I assume that crazy Norwegian is all over the news? AL...
Alan Jones
[Re: LA360]
#1037077
07/26/11 04:12 AM
07/26/11 04:12 AM
mafo
Finland
very little snow now... and you are right about the norwegian, ![](/ubbthreads/images/graemlins/puke.gif)
[Re: mafo]
#1037080
07/26/11 04:35 PM
07/26/11 04:35 PM
Posts: 2,578 sweden
1Fast340
sweden
that norwegian ![](/ubbthreads/images/graemlins/no.gif)
