r3 with indy heads #1037064
07/21/11 01:20 AM
07/21/11 01:20 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
will my indy cnc 245 ,go on r3 48 degree block with machining more room on the pushrod slots ,can i turn down my scat 4340 360 jernal size to run in it what cubes piston/rods would be best with this combo i will hit it with 200-300 of gas are they easy to covert to wet oil system thanks
Re: r3 with indy heads [Re: Ian] #1037065
07/21/11 01:28 AM
07/21/11 01:28 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Every set of small block indy heads I've used had to be clearanced for 59 degree blocks. I always wanted to throw them on a 48 degree block because I think they would clear with a lot less hassle.
Yes you can turn the 360 mains down to 340/318 size. Don't know how easy it is to convert to wet sump.
Re: r3 with indy heads [Re: dodgeboy11] #1037066
07/21/11 01:46 AM
07/21/11 01:46 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks for that ,i had to clearance them az well on my 59 degree ,any thoughts on rods and pistons 430-440 cubic inch ,can i mill the indy intake to fit .
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: r3 with indy heads [Re: Ian] #1037067
07/21/11 04:11 AM
07/21/11 04:11 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
What R3 block did you buy Ian? A 9", 9.2" or 9.6" deck height block? I have a list somewhere that has the part numbers and basic specs.
Without knowing what deck height Block you have, it will be difficult to recommend a rotating assembly.
Alan Jones
Re: r3 with indy heads [Re: Ian] #1037068
07/21/11 01:27 PM
07/21/11 01:27 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
hello mate! i have a 59 deg 440ci sb with indy 360-1's if u look up 440sb in the search forum, u should see a post Ryanj wrote about my motor..he also said how nice and easy push rods worked using a 1.65 rocker (mine r t@d) not indy junk!best a luck mate
Re: r3 with indy heads [Re: LA360] #1037069
07/21/11 01:30 PM
07/21/11 01:30 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
hi al its
r3 block p4532907 it was givin to me ex prostock engine it is bare not sure what bore size or deck it has no caps it will cost me 400 freight to my door
Re: r3 with indy heads [Re: Ian] #1037070
07/22/11 03:05 PM
07/22/11 03:05 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
any other ideas on a combo for this can you get of the shelf pistons for 4.200 0r 4.180 bore
Re: r3 with indy heads [Re: Ian] #1037071
07/23/11 04:32 AM
07/23/11 04:32 AM
LA360 Offline
LA360  Offline
Did you get it off Graig Geddes by chance? I know he had one at one stage. He had some 60mm core roller cams he was selling cheap also.
In the pics you sent me, it looks like it has keyway lifter bores, and they don't look like they are in the standard position. I would measure the spacing to be sure. It should be 1.76", but these Comp and PST guys would move things around.
Bore space is going to be around the 4.180"-4.20" mark, with a deck height of around 8.8"-8.9". If you are lucky it's an early engine with 318 mains, otherwise it will have ford 2.25" mains.
The oiling for wet sump will require a few galleries to be drilled, and drain backs added to the lifter valley. Is the bottom of the cam tunnel enclosed?
I have a NIB Comp Cams 60mm Solid Roller, but I doubt it is going to be suited to your combo. Plus you drive that AP6 of yours abit, it would kill too many sets of valve springs!
With any luck Mafo (Ken) chimes in, he has an ex Nickens or Patterson PST engine. Ken is quite helpful.
Alan Jones
Re: r3 with indy heads [Re: LA360] #1037072
07/23/11 04:48 AM
07/23/11 04:48 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
i got 3 cams and block for 2 slabs craig is a good mate of mine and yes it was his ,if it all works out it will be good i am trying for 420 cubic inchs
Re: r3 with indy heads [Re: Ian] #1037073
07/23/11 06:35 AM
07/23/11 06:35 AM
LA360 Offline
LA360  Offline
I didn't know he still had the block, I remember him telling me in an email that he picked up some Chrysler stuff in a deal he'd done on a car, he tried selling the stuff, but surprise surprise, no one wanted it over here.
I imagine you are going to change the lifter bore bushings? Check the block for cranks, some of that PST stuff was lightened alot and crack.
Craig might know of some billet cranks for one of those things, but you're not going to be getting any more than a 3.75"-3.8" stroke crank into it, the deck height will be too short.
Let me know if you need anything, I have a couple of odds and sods left over from the W8 engine I was building before I decided to go with a P7 deal.
Alan Jones
Re: r3 with indy heads [Re: Ian] #1037074
07/24/11 07:55 AM
07/24/11 07:55 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
hi al its
i love the sound of your car mate i have t&d 1.6 cnc 245 indy the block is a low deck is yours i will find your build thanks
Re: r3 with indy heads [Re: LA360] #1037075
07/25/11 03:18 PM
07/25/11 03:18 PM
Finland
mafo Offline
mafo  Offline
Finland
I m here, just not every day this time of the year...short summers here
If you already have the keyway bushings you better step up and get a set of Jesel or Lsm lifters, I got a like new set for 25% of new price, still expensive but outstanding quality
R3 blocks are usually with 340 mains , I believe R4 s are Ford
For oiling you may go with an external pump, then you don t have to drill anything, easy to prelube and pressure adjustment, you just have to live with that extra belt...
I have 3.55 stroke in mine and everything fits easily, most problems I have had is related to somekind of water leaks, both heads and block
good luck to you and I m glad if I can help
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: r3 with indy heads [Re: mafo] #1037076
07/25/11 10:45 PM
07/25/11 10:45 PM
LA360 Offline
LA360  Offline
P5007360AB featured 9.025" nominal deck height, Ford 2.25" mains, a 60mm tunnel, steel 4 bolt caps and 48* lifter bores. Although many were ordered without lifter bores.
How is the winter over there Ken? I assume that crazy Norwegian is all over the news?
AL...
Alan Jones
Re: r3 with indy heads [Re: LA360] #1037077
07/26/11 04:12 AM
07/26/11 04:12 AM
Finland
mafo Offline
mafo  Offline
Finland
very little snow now...
and you are right about the norwegian,
Re: r3 with indy heads [Re: mafo] #1037078
07/26/11 08:01 AM
07/26/11 08:01 AM
LA360 Offline
LA360  Offline
Alan Jones
Re: r3 with indy heads [Re: LA360] #1037079
07/26/11 12:26 PM
07/26/11 12:26 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks alan
Re: r3 with indy heads [Re: mafo] #1037080
07/26/11 04:35 PM
07/26/11 04:35 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
that norwegian
