Is this a good deal??? hemi world block #1034047
07/17/11 12:05 PM
07/17/11 12:05 PM
West Central Florida
doncarson Offline OP
I'm building a budget hemi motor for my 65 coronet , low cost, reliable, good power. I see Bill Mitchell has the aluminum world hemi block 4.90 bare block (not fully prepped) w/o lifter bores drilled for $2995. +$250 shipping. That's cheap..
Should I get that and pay for the lifters and prepping or go with a fully prepped block for a LOT more money.
I'm thinking the machine shop can do the prepping AND make sure all is right at the same time.
What is the typical cost for the lifters to be bored and prepping the bare block?
As several here have suggested my motor will have a flat tappet cam off the shelf stroker kit and get a decent set of heads for now.
The goal is to run mid to high 10s for FUN nostalgia events.
Attached is a pic of the car. Now that it looks fast I have to make it run fast!.
Thanks all
Don
Re: Is this a good deal??? hemi world block [Re: doncarson] #1034048
07/17/11 12:22 PM
07/17/11 12:22 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
wild guess here...cost me $500 to bush the lifter bores...Im assuming to machine or bore lifter bores would probably be another 500 or so...could be a hundred less....
so Im going to say about $1,000 to do those complete..
and I wanted to say..at least another $350 for prep and then theres boring, honing...maybe another 800 there??
Re: Is this a good deal??? hemi world block [Re: smokinwoody] #1034049
07/17/11 12:25 PM
07/17/11 12:25 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
$1,000, cost similar here across the pond.
How goes it Woody
Re: Is this a good deal??? hemi world block [Re: mopar_mark] #1034050
07/17/11 12:26 PM
07/17/11 12:26 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Yo Mark...long time....dont want to hawk his post...
Re: Is this a good deal??? hemi world block [Re: doncarson] #1034051
07/17/11 12:46 PM
07/17/11 12:46 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Cheap, Hemi, Aluminum Block, low budget, all in the same sentence....LOL
If its a budget build, why not get a chrysler cast iron block? They typically go for $2900 or so, and be done with it....
PS..World was the one stating ARP main studs, and many found out they weren't. Maybe look into the cost of that if it ends up being the case as well...Line boring a Hemi is not cheap.
Re: Is this a good deal??? hemi world block [Re: doncarson] #1034052
07/17/11 05:05 PM
07/17/11 05:05 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think that's a good deal and I would do it. I would shop for someone to do the lifter bores. With any type of engine machining I shop for quality of work NOT price.
My first thought was you should just buy an iron block if you're trying to save money, but I do think you are on the right track going aluminum, just for the repairability issue.
You should be able to run mid to high tens with a stock 426 Hemi with a bigger cam and headers if that chassis will hook at all and you run a decent convertor. I would build it once and build it for a bit stronger performance.
Sheldon
Re: Is this a good deal??? hemi world block [Re: Dragula] #1034053
07/18/11 10:10 AM
07/18/11 10:10 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
But, that doesn't take into account what a good deal the aluminum ones are, or evolution of the engine/car. An iron one can take you a long way though.
Rich H.
Esse Quam Videri
Re: Is this a good deal??? hemi world block [Re: ZIPPY] #1034054
07/18/11 10:21 AM
07/18/11 10:21 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Call Jim Kilpatrick in waukesha wi
he is the hemi guy up that way.
i know he can do all the machining in house
Re: Is this a good deal??? hemi world block [Re: ZIPPY] #1034055
07/18/11 10:36 AM
07/18/11 10:36 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
By the time you have all the work done, plus shipping and all that, you'll be right at what you would have spent on a Keith Black. And it won't be a Keith Black.....
S/F.....Ken M
Re: Is this a good deal??? hemi world block [Re: doncarson] #1034056
07/18/11 06:43 PM
07/18/11 06:43 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Aren't those $2995 blocks raised cam also?
Can you get a timing chain set or would you have to get a belt drive?
Re: Is this a good deal??? hemi world block [Re: RTSE4ME] #1034057
07/18/11 07:52 PM
07/18/11 07:52 PM
Yes the block listed is a raised cam location block.
Here are the specs:
TECHNICAL SPECS
Material: 357-T6 Aluminum
Deck Height: 10.725"
Deck Thickness: .600" minimum
Cam Bearings: Stock (can be machined for 60mm)
Camshaft Location: raised +.250"
Lifter Bores: None
Bellhousing: Dual (accomodates stock and GM)
Bore: 4.490" Rough
Maximum Bore: 4.530" Larger possible but engine builder preference
Water Jackets: Expanded for better cooling
Lubrication: Priority main oiling system
Crank Clearance: 4.500"Std 4.750"max stroke (with external oil line)
Main Caps: Nodular (Ductile) Front four caps 4-bolts and crossed bolted
Fuel Pump: OEM mount
Starter: OEM mount
Motor Mounts: Dual (front and side)
Cylinder Head Holes: Blind tapped to prevent leaks
Weight: Approximately 142 lbs.
Re: Is this a good deal??? hemi world block [Re: joshking440] #1034058
07/18/11 07:59 PM
07/18/11 07:59 PM
Hey joshking.
Jim K. has done a lot of work for me. He built my 440 short block and transmission for a max wedge clone I had and he has helped me out with other projects. I actually called him today about the work. He did say he has a sweet 540 hemi that is ready to go is a killer motor..........
Don
Re: Is this a good deal??? hemi world block [Re: doncarson] #1034059
07/20/11 12:03 AM
07/20/11 12:03 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That does sound like a wise purchase.As far as the lifter bores,after reading DRAM's thread on his CNC program on lifter bore correction I would not do it any other way.I know that many machine shops have used thier "fixture" to drill & hone.The precise ability of the CNC proceedure is the only way to go.Maybe Dan will chime in with a statement.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Is this a good deal??? hemi world block [Re: hemi-itis] #1034060
07/20/11 12:38 AM
07/20/11 12:38 AM
Delray beach, Florida
P
Performance Only Offline
P
we have the equipment to put the lifter bores in. i agree that a CNC is the most accurate and the least expensive way to do that job.
machine shop owner and engine builder
Re: Is this a good deal??? hemi world block [Re: doncarson] #1034061
07/20/11 07:15 AM
07/20/11 07:15 AM
SW WI
cudacustoms1 Offline
SW WI
If you do go with this block and need some work done on it give the guys at goodwin compitition a call. They are doing mine now and have been great to deal with. They are in wisconsin.
Re: Is this a good deal??? hemi world block [Re: cudacustoms1] #1034062
07/20/11 10:59 AM
07/20/11 10:59 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
top notch people there!! Will go out of their way for a Mopar friend!
Re: Is this a good deal??? hemi world block [Re: cudacustoms1] #1034063
07/21/11 07:51 AM
07/21/11 07:51 AM
Hey cudacustoms1;
Chad I tried emailimg you and the email is bad.
shoot me a PM please I have a couple of questions on your build and Godwin's
Thanks,
Don
