Is this a good deal??? hemi world block
#1034047
07/17/11 12:05 PM
07/17/11 12:05 PM
Posts: 68 West Central Florida
doncarson
I'm building a budget hemi motor for my 65 coronet , low cost, reliable, good power. I see Bill Mitchell has the aluminum world hemi block 4.90 bare block (not fully prepped) w/o lifter bores drilled for $2995. +$250 shipping. That's cheap..
Should I get that and pay for the lifters and prepping or go with a fully prepped block for a LOT more money. I'm thinking the machine shop can do the prepping AND make sure all is right at the same time.
What is the typical cost for the lifters to be bored and prepping the bare block? As several here have suggested my motor will have a flat tappet cam off the shelf stroker kit and get a decent set of heads for now. The goal is to run mid to high 10s for FUN nostalgia events.
Attached is a pic of the car. Now that it looks fast I have to make it run fast!. Thanks all Don
Re: Is this a good deal??? hemi world block
[Re: doncarson]
#1034048
07/17/11 12:22 PM
07/17/11 12:22 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
wild guess here...cost me $500 to bush the lifter bores...Im assuming to machine or bore lifter bores would probably be another 500 or so...could be a hundred less....
so Im going to say about $1,000 to do those complete..
and I wanted to say..at least another $350 for prep and then theres boring, honing...maybe another 800 there??
[Re: doncarson]
#1034051
07/17/11 12:46 PM
07/17/11 12:46 PM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
Cheap, Hemi, Aluminum Block, low budget, all in the same sentence....LOL If its a budget build, why not get a chrysler cast iron block? They typically go for $2900 or so, and be done with it.... PS..World was the one stating ARP main studs, and many found out they weren't. Maybe look into the cost of that if it ends up being the case as well...Line boring a Hemi is not cheap.
[Re: joshking440]
#1034058
07/18/11 07:59 PM
07/18/11 07:59 PM
doncarson
Hey joshking. Jim K. has done a lot of work for me. He built my 440 short block and transmission for a max wedge clone I had and he has helped me out with other projects. I actually called him today about the work. He did say he has a sweet 540 hemi that is ready to go is a killer motor.......... Don
[Re: doncarson]
#1034059
07/20/11 12:03 AM
07/20/11 12:03 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
That does sound like a wise purchase.As far as the lifter bores,after reading DRAM's thread on his CNC program on lifter bore correction I would not do it any other way.I know that many machine shops have used thier "fixture" to drill & hone.The precise ability of the CNC proceedure is the only way to go.Maybe Dan will chime in with a statement.
[Re: hemi-itis]
#1034060
07/20/11 12:38 AM
07/20/11 12:38 AM
Posts: 2,091 Delray beach, Florida
Performance Only
we have the equipment to put the lifter bores in. i agree that a CNC is the most accurate and the least expensive way to do that job.
machine shop owner and engine builder
[Re: cudacustoms1]
#1034062
07/20/11 10:59 AM
07/20/11 10:59 AM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
If you do go with this block and need some work done on it give the guys at goodwin compitition a call. They are doing mine now and have been great to deal with. They are in wisconsin.
top notch people there!! Will go out of their way for a Mopar friend!
