Which posi brand is better? #103388
08/11/08 07:46 PM
08/11/08 07:46 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
I want to change my rear end from opem to posi. My case is 741 and I need to now wich brand is better: youkon cluch type or auburn cone type?
thanks.
Re: Which posi brand is better? [Re: v8punch] #103389
08/11/08 08:11 PM
08/11/08 08:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Clutch type because it's rebuildable.
Re: Which posi brand is better? [Re: stumpy] #103390
08/11/08 08:17 PM
08/11/08 08:17 PM
southern Idaho
moparcyco Offline
moparcyco  Offline
southern Idaho
Re: Which posi brand is better? [Re: v8punch] #103391
08/11/08 09:50 PM
08/11/08 09:50 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
thanks.
clutch type , do not waste a penny on any cone type , especially the auburn
Re: Which posi brand is better? [Re: JohnRR] #103392
08/12/08 09:20 AM
08/12/08 09:20 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
thanks.
110%
Dr Diff - Cass sells them and all the hardware you will need...
Re: Which posi brand is better? [Re: Cuda340] #103393
08/12/08 09:22 AM
08/12/08 09:22 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Anyone ever use an air-locker ?
Re: Which posi brand is better? [Re: v8punch] #103394
08/12/08 11:06 AM
08/12/08 11:06 AM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
Drop the extra cash and get a Detroit Locker or True Trac, better than cone or clutch.
Re: Which posi brand is better? [Re: Moonraker] #103395
08/12/08 11:17 AM
08/12/08 11:17 AM
NY usa
540challenger Offline
NY usa
i love my true trac if you do more street driving get the truc trac if you more oon the drag strip go with the locker.
Re: Which posi brand is better? [Re: v8punch] #103396
08/12/08 11:30 AM
08/12/08 11:30 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
8 replies and nobody's you for calling is a posi rather than a sure-grip.....Moparts must be getting soft!
Based on the sage advice here (and Johnrr's comments in particular) I purchased a clutch type unit for the Super Bee. Of course at this rate, it'll last forever since the car seems it'll never be done!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Which posi brand is better? [Re: DPelletier] #103397
08/12/08 11:34 AM
08/12/08 11:34 AM
NY usa
NY usa
posi doesn't bother me as much as when someone calls a six pac a tripower then all
Re: Which posi brand is better? [Re: DPelletier] #103398
08/12/08 12:37 PM
08/12/08 12:37 PM
JohnRR Offline
JohnRR  Offline
too many brand X guys have jumped ship and infested mopars , instead we just point, snicker and shake our heads when someone says the word posi
plus he is asking about the auburn which IS a posi POS .
Re: Which posi brand is better? [Re: JohnRR] #103399
08/12/08 01:15 PM
08/12/08 01:15 PM
DPelletier Offline
DPelletier  Offline
OK, now I'm clear on the appropriate protocol!
Re: Which posi brand is better? [Re: DPelletier] #103400
08/12/08 01:19 PM
08/12/08 01:19 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I HAVE TO call it POSI no matter what, since NOBODY in Venezuela knows the name SUREGRIP
Re: Which posi brand is better? [Re: NachoRT74] #103401
08/12/08 04:13 PM
08/12/08 04:13 PM
dogdays Offline
dogdays  Offline
Get with DrDiff (board Member) and buy a Dana Spicer POWR-LOK which is the industry standard for limited slip differentials. It's very strong, rebuildable and there is one for an 8 3/4 rear.
Cost is very reasonable.
R.
I had to go on the Dana webpage to get the right spelling.
Re: Which posi brand is better? [Re: dogdays] #103402
08/12/08 08:04 PM
08/12/08 08:04 PM
MG, Brazil
v8punch Offline OP
v8punch  Offline OP
MG, Brazil
I saw on ebay a SUREgrip clutch tipe for a good price... the seller said its the original brand....
I have a 383 450hp challenger but with open rear end type and I don´t now the ratio... probably 2.79(76?) o 3.23...
The case is 471, I'll need only the suregrip unit, bearings and gears 3.55 or I'll need more parts?
Thanks guys.... sorry about posi... I'm a MOPAR guy, and a Ford Mavevikc guy too..... but never brand X guy!
One more question: Can I use the larger pinion on 471 case? What I'll need to do to use it?
Thanks.
Re: Which posi brand is better? [Re: v8punch] #103403
08/12/08 11:18 PM
08/12/08 11:18 PM
Moonraker Offline
Moonraker  Offline
Thanks.
No pinion diameters are specific for for each case housing i.e. 741, 742, and 489 etc. 741 cases are considered weak by some peoples standards but I'll attach the following thread by DrDiff a fellow board member that explains a lot.
http://www.moparts.org/Tech/Archive/axle/1.html
Re: Which posi brand is better? [Re: Moonraker] #103404
08/13/08 10:39 AM
08/13/08 10:39 AM
dogdays Offline
dogdays  Offline
I'd rather have a brand new one from DrDiff than a used one from the 'bay, even if it meant spending an extra $200. Dana Spicer was the original manufacturer of the POWR-LOK, it is a blessing that these are now in production again. IIRC the new price is below $500.
R.
