Which posi brand is better?
#103388
08/11/08 07:46 PM
08/11/08 07:46 PM
Posts: 302 MG, Brazil
v8punch
MG, Brazil
I want to change my rear end from opem to posi. My case is 741 and I need to now wich brand is better: youkon cluch type or auburn cone type? thanks.
Re: Which posi brand is better?
[Re: v8punch]
#103391
08/11/08 09:50 PM
08/11/08 09:50 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
clutch type , do not waste a penny on any cone type , especially the auburn
[Re: JohnRR]
#103392
08/12/08 09:20 AM
08/12/08 09:20 AM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
110%
Dr Diff - Cass sells them and all the hardware you will need...
[Re: Moonraker]
#103395
08/12/08 11:17 AM
08/12/08 11:17 AM
Posts: 2,826 NY usa
540challenger
NY usa
Drop the extra cash and get a Detroit Locker or True Trac, better than cone or clutch.
i love my true trac if you do more street driving get the truc trac if you more oon the drag strip go with the locker.
[Re: v8punch]
#103396
08/12/08 11:30 AM
08/12/08 11:30 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
8 replies and nobody's you for calling is a posi rather than a sure-grip.....Moparts must be getting soft! Based on the sage advice here (and Johnrr's comments in particular) I purchased a clutch type unit for the Super Bee. Of course at this rate, it'll last forever since the car seems it'll never be done! Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#103397
08/12/08 11:34 AM
08/12/08 11:34 AM
Posts: 2,826 NY usa
540challenger
NY usa
posi doesn't bother me as much as when someone calls a six pac a tripower then all
[Re: NachoRT74]
#103401
08/12/08 04:13 PM
08/12/08 04:13 PM
dogdays
Get with DrDiff (board Member) and buy a Dana Spicer POWR-LOK which is the industry standard for limited slip differentials. It's very strong, rebuildable and there is one for an 8 3/4 rear.
Cost is very reasonable.
R.
I had to go on the Dana webpage to get the right spelling.
[Re: dogdays]
#103402
08/12/08 08:04 PM
08/12/08 08:04 PM
v8punch
MG, Brazil
I saw on ebay a SUREgrip clutch tipe for a good price... the seller said its the original brand.... I have a 383 450hp challenger but with open rear end type and I don´t now the ratio... probably 2.79(76?) o 3.23... The case is 471, I'll need only the suregrip unit, bearings and gears 3.55 or I'll need more parts? Thanks guys.... sorry about posi... I'm a MOPAR guy, and a Ford Mavevikc guy too..... but never brand X guy!
One more question: Can I use the larger pinion on 471 case? What I'll need to do to use it? Thanks.
[Re: v8punch]
#103403
08/12/08 11:18 PM
08/12/08 11:18 PM
Posts: 666 Anywhere the British Secret Se...
Moonraker
No pinion diameters are specific for for each case housing i.e. 741, 742, and 489 etc. 741 cases are considered weak by some peoples standards but I'll attach the following thread by DrDiff a fellow board member that explains a lot. http://www.moparts.org/Tech/Archive/axle/1.html
[Re: Moonraker]
#103404
08/13/08 10:39 AM
08/13/08 10:39 AM
dogdays
I'd rather have a brand new one from DrDiff than a used one from the 'bay, even if it meant spending an extra $200. Dana Spicer was the original manufacturer of the POWR-LOK, it is a blessing that these are now in production again. IIRC the new price is below $500.
R.
