Thoughts on Hemi crate vs Indy #1032611
07/14/11 05:11 PM
07/14/11 05:11 PM
West Central Florida
doncarson Offline OP
Need first hand help on what to run...
I want to drop in a hemi in my 65 coronet 2dr post for FUN nostalgia racing NOT weekly competitive, just a fast RELIABLE hemi super stock style clone. I really want to run around 10.50 ETs.
The car is now a 383 bracket car w/ roll bar, SS springs, and a few race goodies nothing special. Weighs 3750lbs.
With the hemi I am planning on a dana w/ 456 spool and beefy 727 ( $2500.- 3000. build) but I can't spend $20k on a motor.
I want the crossram and chrome valve covers look. But both the Mopar crate 426 465HP can buy as low as $12,995!. and 472 530 HP $15,995. come with single plane and I would have to spend another $2k or so. The Indy 572 770hp is $16,995 which is a killer motor BUT again the crossram upgrade is $3,450. and will not accept stock valve covers.
Is it a good idea to go with the 465 HP and add a better cam, still only around 500HP?
What motor do you run or recommend to get me 10.50s and keep the super stock crossram look AND a fun, reliable motor?? The car will NOT be for the street, but NOT an all out race car.
Thanks,
Don
Re: Thoughts on Hemi crate vs Indy [Re: doncarson] #1032612
07/14/11 05:14 PM
07/14/11 05:14 PM
tboomer Offline
tboomer  Offline
Don...Bob George Racing...
Re: Thoughts on Hemi crate vs Indy [Re: doncarson] #1032613
07/14/11 06:01 PM
07/14/11 06:01 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
check out muscle motors!!!!!!!!
Re: Thoughts on Hemi crate vs Indy [Re: doncarson] #1032614
07/14/11 06:02 PM
07/14/11 06:02 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Re: Thoughts on Hemi crate vs Indy [Re: rickraw] #1032615
07/14/11 06:07 PM
07/14/11 06:07 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I wouldn't buy a briggs n stratton from indy.
Re: Thoughts on Hemi crate vs Indy [Re: tboomer] #1032616
07/14/11 06:49 PM
07/14/11 06:49 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
now close to 300 trouble free passes with my 588" from BG.
home of the
Sox and Martin Hemi Duster
Re: Thoughts on Hemi crate vs Indy [Re: HEMIFRED] #1032617
07/14/11 06:53 PM
07/14/11 06:53 PM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
RUN away from INDY.
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: Thoughts on Hemi crate vs Indy [Re: viperblue72] #1032618
07/14/11 06:55 PM
07/14/11 06:55 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
aren't they wonderful to the normal buyer? lol go through bg racing
Re: Thoughts on Hemi crate vs Indy [Re: fishy340] #1032619
07/14/11 07:17 PM
07/14/11 07:17 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Talk to Bob at Bob George Racing, great guy. Dave
Re: Thoughts on Hemi crate vs Indy [Re: quickd100] #1032620
07/14/11 07:20 PM
07/14/11 07:20 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Call Bob George! He has HEMI's sitting in his shop.
Re: Thoughts on Hemi crate vs Indy [Re: HEMIDARTS] #1032621
07/14/11 08:32 PM
07/14/11 08:32 PM
MI
68shifter Offline
68shifter  Offline
MI
I wouldn't buy from Indy if you payed me.
I called them yesterday for a quick question on spring pressure on a set of heads I spent alot of money on. The guy was such a jerk for a simple spring pressure question that I just said screw it and hung up.
Good luck. Sounds like a cool combo.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Thoughts on Hemi crate vs Indy [Re: doncarson] #1032622
07/14/11 11:23 PM
07/14/11 11:23 PM
Wow! I guess Indy is off my list for suew.
I will call BG racing and see what they can do for me.
Thanks for your help.
At 3800lbs with 4.56, 727 4000 converter does 650hp sound about right to get me around 10.50 ETs?
Thanks guys,
Don
Re: Thoughts on Hemi crate vs Indy [Re: doncarson] #1032623
07/14/11 11:38 PM
07/14/11 11:38 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Only problem you will have with BGR is running 10.50's.........
You will have to put a brick under the pedal to keep it out of the 9's...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Thoughts on Hemi crate vs Indy [Re: Eric] #1032624
07/15/11 10:15 AM
07/15/11 10:15 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
For your purpose, you need something custom built, not chosen off a menu.
You want reliable, low maintenence, not too costly, 700 + horsepower.
If I was you, I would build a 540, 4.5 bore x 4.25 stroke, about 12.5 to 1 compression, with steel rods and all off the shelf parts, plus a flat tappet cam with about .650 lift, that is probably the cheapest short block you can build. Put your $$ into a really nice flowing set of heads.
Don't get too exotic with rods, rings and pistons, you don't need to spend the $ or deal with the maintenence. Roller cams are great for making power, but to run 10.50's you don't need it, and again it is a lot more $$ and maintenence to run a roller cam. If you keep the lift down in the .650 range, and the rpm reasonable, you won't need high dollar, high maintenence valve train parts, just use stock rockers with decent push rods and the motor will live for many years.
If you decide later you want to go 10.0's, just upgrade to a roller cam and better valve train and you'll be ready to go. Good luck! Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Thoughts on Hemi crate vs Indy [Re: Hemi_Joel] #1032625
07/15/11 10:31 AM
07/15/11 10:31 AM
Thanks for the info Hemi-Joel.
That is just what I'm looking for.
I appreciate all the info.
I'll be going to the Chicago Mopar Happening this weekeng and start my hunt.
All the best,
Don
Re: Thoughts on Hemi crate vs Indy [Re: Hemi_Joel] #1032626
07/15/11 11:07 AM
07/15/11 11:07 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
X2
