Hood adjustment on 69 Dart #1029665
07/10/11 08:42 PM
07/10/11 08:42 PM
Camarillo, CA.
P
preston Offline OP
preston  Offline OP
P
Camarillo, CA.
I have checked the archives but was unable to find anything on hood adjustment. I have been able to get the hood to fit good all the way around except in the the back where it sticks up about a 1/2" above the cowl. It seems no matter what I do I cannot get it down. What am I doing wrong. Thanks Bob
Re: Hood adjustment on 69 Dart [Re: preston] #1029666
07/10/11 08:49 PM
07/10/11 08:49 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The hood hinges on 67 and later a-body cars mount on two fixed studs in front of the door jamb so you really can't adjust them up or down.
Once they start staying up like that it's usually time for a rebuild. If you let it go the hinges will start bowing outward and will rub the paint off the inside of the fenders.
Resto Rick, a Moparts board sponsor, is a good guy to send your hinges to for a rebuild.
Re: Hood adjustment on 69 Dart [Re: preston] #1029667
07/10/11 09:56 PM
07/10/11 09:56 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Unless the hood was somehow damaged, there is usually plenty of range built in to get the hood aligned right.
The slots in the hinge allow fore and aft adjustment as well as some for up and down. I suppose that you could elongate the slot to get more range. Maybe you could go to a local car show and belly up to a participant to get a few tips. Being in person may make things much clearer.
Re: Hood adjustment on 69 Dart [Re: Kern Dog] #1029668
07/10/11 10:05 PM
07/10/11 10:05 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
this is something best done with a helper or two. My guess is that loosening the rear 4 bolts and having two helpers shift the hood into proper position, then retighten while they hold it still.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Hood adjustment on 69 Dart [Re: GO_Fish] #1029669
07/11/11 01:27 AM
07/11/11 01:27 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
REAR 4 bolts?
There are only 4 bolts holding the hood on...total.
Maybe if the rear 2 bolts are loosened and a helper tries to raise the hood, this will allow the rear edge of the hood to move closer to the hinge, which equates to it sitting lower when at rest.
Re: Hood adjustment on 69 Dart [Re: Neil] #1029670
07/11/11 01:50 AM
07/11/11 01:50 AM
Camarillo, CA.
P
preston Offline OP
preston  Offline OP
P
Camarillo, CA.
Thanks for the info guys. I think you may be right Neil. I noticed that the hinges are bowing outward when you lower the hood and it seems a little more difficult to lower than it was a few years back when I disassembled the car to restore. Looks like I will need to restore the hinges. Thanks again Bob
Re: Hood adjustment on 69 Dart [Re: preston] #1029671
07/11/11 02:01 AM
07/11/11 02:01 AM
Red Lion, PA USA
scamper340 Offline
scamper340  Offline
Red Lion, PA USA
Until you rebuild the hinges, try spraying the hinges really good with penetrating oil. I mean really hose it down and work the hood up and down to get any grit out of the hinges. Helped out on mine big time. Mine opens and closes like butter now and the hinges don't bow nearly as much.
Re: Hood adjustment on 69 Dart [Re: scamper340] #1029672
07/11/11 12:01 PM
07/11/11 12:01 PM
Camarillo, CA.
P
preston Offline OP
preston  Offline OP
P
Camarillo, CA.
Thanks scamper340, I will try that today and see if it helps. It would make things a whole lot easier. Bob
