Mcleod clutch with no peddle feel #102687
08/10/08 10:49 PM
08/10/08 10:49 PM
Rohnert Park, Ca
ryan053 Offline OP
ryan053  Offline OP
Rohnert Park, Ca
I just installed a new mcleod clutch in my 68 charger. It was pieced together by brewers based on my engine combo. I installed it with a 1/4" of space between the throwout bearing and the pressure plate. Thats what the mcleod instructions say to do. when i depress the peddle it has no resistance at all. I havent started the new engine so im not sure if it will work ok. How much resistance is there in your guys clutches. Its the diaphragm style
Re: Mcleod clutch with no peddle feel [Re: ryan053] #102688
08/10/08 10:59 PM
08/10/08 10:59 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
can you put it into gear?
I think a 1/4" might be too much, but I don't know. I have a 3 finger hydro clutch and the directions said to have between .125 and .180 (or somewhere around there) of space from the bearing to the fingers. I usually set it at just less than 3/16"
**Photobucket sucks**
Re: Mcleod clutch with no peddle feel [Re: 70Cuda383] #102689
08/10/08 11:10 PM
08/10/08 11:10 PM
Rohnert Park, Ca
ryan053 Offline OP
ryan053  Offline OP
Rohnert Park, Ca
Yeah it shifts into all the gears. I have to push the peddle about half way down before i get any resistance. once i get the car going i can mess with it more but i was just curious if that is how a diaphragm pressure plate feels
Re: Mcleod clutch with no peddle feel [Re: ryan053] #102690
08/10/08 11:24 PM
08/10/08 11:24 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It's a diaphram clutch you have to remove the big over center spring off the clutch peddle, mopars did not use that type of clutch originally
Re: Mcleod clutch with no peddle feel [Re: JohnRR] #102691
08/10/08 11:35 PM
08/10/08 11:35 PM
Rohnert Park, Ca
ryan053 Offline OP
ryan053  Offline OP
Rohnert Park, Ca
I took the spring out.
Re: Mcleod clutch with no peddle feel [Re: ryan053] #102692
08/11/08 12:11 AM
08/11/08 12:11 AM
JohnRR Offline
JohnRR  Offline
then that's the way it is .
Re: Mcleod clutch with no peddle feel [Re: JohnRR] #102693
08/11/08 12:27 AM
08/11/08 12:27 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.......Mopars really don't "respond" well to those diaphram clutches,........should have gone with a 3 finger Borg/ Beck design in the 2400-2800 lbs range.......usally with the diapham set ups, any high rpm shifts, usally result with the pedal "laying" on the floor.....from my experiences .......lets us know how you make out.........
Re: Mcleod clutch with no peddle feel [Re: DAYCLONA] #102694
08/11/08 05:39 PM
08/11/08 05:39 PM
Rohnert Park, Ca
ryan053 Offline OP
ryan053  Offline OP
Rohnert Park, Ca
the guys at brewers said there was no performance difference in going with one or the other. I figured at least if i get a diaphragm style then i can let anyone drive the car without them getting a leg workout. I guess i will see how it is in a few days
Re: Mcleod clutch with no peddle feel [Re: ryan053] #102695
08/12/08 09:41 AM
08/12/08 09:41 AM
twin cities
dart_sportsatellite Offline
twin cities
Sounds like mine, 1/4" and soft pedal about half way down, after bleeding it.
