Re: Mcleod clutch with no peddle feel
[Re: ryan053]
#102688
08/10/08 10:59 PM
08/10/08 10:59 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
can you put it into gear?
I think a 1/4" might be too much, but I don't know. I have a 3 finger hydro clutch and the directions said to have between .125 and .180 (or somewhere around there) of space from the bearing to the fingers. I usually set it at just less than 3/16"
**Photobucket sucks**
[Re: JohnRR]
#102693
08/11/08 12:27 AM
08/11/08 12:27 AM
Posts: 18,157 Mass
DAYCLONA
Mass
then that's the way it is .
.......Mopars really don't "respond" well to those diaphram clutches,........should have gone with a 3 finger Borg/ Beck design in the 2400-2800 lbs range.......usally with the diapham set ups, any high rpm shifts, usally result with the pedal "laying" on the floor.....from my experiences .......lets us know how you make out.........
[Re: ryan053]
#102695
08/12/08 09:41 AM
08/12/08 09:41 AM
Posts: 827 twin cities
dart_sportsatellite
twin cities
Yeah it shifts into all the gears. I have to push the peddle about half way down before i get any resistance. once i get the car going i can mess with it more but i was just curious if that is how a diaphragm pressure plate feels
Sounds like mine, 1/4" and soft pedal about half way down, after bleeding it.
