One question about pinion angle. #1025724
07/04/11 01:37 PM
07/04/11 01:37 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Transmission is 3 degrees down. Rear yoke is 0 degrees. I need to go 5 degrees down on the rear yoke? No room to raise tranny up.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: One question about pinion angle. [Re: Junky] #1025725
07/04/11 02:33 PM
07/04/11 02:33 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Found this in the Tech Archives.
http://www.moparts.org/Tech/Archive/axle/8.html
Re: One question about pinion angle. [Re: Junky] #1025726
07/04/11 02:38 PM
07/04/11 02:38 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Your current pinion angle is -3 degrees. Why do you want to change it?
Re: One question about pinion angle. [Re: Neil] #1025727
07/04/11 02:40 PM
07/04/11 02:40 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Thanks, but that is confusing.
Re: One question about pinion angle. [Re: Junky] #1025728
07/04/11 02:41 PM
07/04/11 02:41 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
so is reversing the angle from -3 to +2 degrees
Re: One question about pinion angle. [Re: DoctorDiff] #1025729
07/04/11 02:43 PM
07/04/11 02:43 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I get a vibration, but only when I'm at about 60 mph or faster. It gets worse if I'm going down a hill at 60 mph and I pick up speed, then let off the throttle a bit to keep from picking up too much speed. Otherwise, not accelerating nor decelerating.
It's ok with 3 degrees down on the tranny yoke and 0 degrees at the rear yoke?
Re: One question about pinion angle. [Re: Junky] #1025730
07/04/11 02:45 PM
07/04/11 02:45 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
ever had your drive shaft balanced?
Re: One question about pinion angle. [Re: Junky] #1025731
07/04/11 02:52 PM
07/04/11 02:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Too much positive pinion angle will cause a vibration on acceleration. Too much negative pinion angle will cause a vibration on braking or deceleration.
If your transmission slopes downward 3 degrees toward the rear and your pinion centerline is level, you have a -3 degree pinion angle. I don't usually like to see more than -3 for a street car.
Re: One question about pinion angle. [Re: west] #1025732
07/04/11 03:05 PM
07/04/11 03:05 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
It's a new drive line. Maybe I should take it back to them and have it rechecked.
Re: One question about pinion angle. [Re: DoctorDiff] #1025733
07/04/11 03:06 PM
07/04/11 03:06 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I'm gonna find an expert and have them take care of this. It's confusing.
Re: One question about pinion angle. [Re: Junky] #1025734
07/04/11 03:09 PM
07/04/11 03:09 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
You can easily put shims between the axle and springs if you want to achieve a zero angle. I found some at an off road shop.
Re: One question about pinion angle. [Re: west] #1025735
07/04/11 06:56 PM
07/04/11 06:56 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
So theres no way to lift the tailshaft up any? I had mine at 0 & plenty of lift before it hit the floor, I like setting tailshaft at 0 & then drop the pinion 3* down for -3*, I had mine this way & no vibration that i could tell.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: One question about pinion angle. [Re: Junky] #1025736
07/04/11 10:03 PM
07/04/11 10:03 PM
NY
KillerB Offline
KillerB  Offline
NY
Is there any angle shims on leafs? If not, add 2degree down on rear that should fix your vibration under load. But make sure your driveshaft is balanced before anything.
Re: One question about pinion angle. [Re: KillerB] #1025737
07/05/11 02:20 AM
07/05/11 02:20 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I'm going to try it your way. Both balance check and shims. Trial and error on the shims. Not hard to had or subtract them.
