PROMAX SIX PACK 6/32" PLUG
#1024287
07/02/11 03:04 AM
07/02/11 03:04 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Anyone know what the purpose of the 6/32" soft brass plug is that PROMAX supplies with their six pack center carb metering block? Is it critical? Tonight I've had trouble making it fit into the carb -- hex wrench stripped the center hole of the plug, so now the plug is barely into the carb unit and hanging out rather than fully seated. I think its for the blocking of the vacuum advance port from the carb. Can it be epoxied/closed if I cut it off? Thanks ahead to anyone who can help (I'll try PROMAX Sat morning). Mopar Mitch
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: PROMAX SIX PACK 6/32" PLUG
[Re: Mopar Mitch]
#1024288
07/02/11 10:04 AM
07/02/11 10:04 AM
gtx69
super gas
super gas
[Re: gtx69]
#1024289
07/02/11 01:52 PM
07/02/11 01:52 PM
Mopar Mitch
I called Proamx sat morng... no answer... left message.... i'm stuck for now til i get an answer on that plug... I know its used for a vacumm from the missing dist advance tube from the new metering block... its the lower left carb hole just to the right of the lower left bolt hole.
thanks
Mopar Mitch
[Re: Mopar Mitch]
#1024290
07/02/11 08:07 PM
07/02/11 08:07 PM
gtx69
super gas
super gas
[Re: WICKD6PK]
#1024292
07/03/11 02:36 AM
07/03/11 02:36 AM
Mopar Mitch
Thanks for the tip on the proper metering block, and the questionable plug.
Mopar Mitch
[Re: Mopar Mitch]
#1024293
07/06/11 05:37 PM
07/06/11 05:37 PM
Mopar Mitch
I finally spoke with Ben at Promax... he said the plug is rarely needed only when the carb hole happens to be mis-located... and mine is OK... plug not needed! (they should've said this on their info sheet and it would've saved me the time delay). Issue closed!
Mopar Mitch
