PROMAX SIX PACK 6/32" PLUG #1024287
07/02/11 03:04 AM
07/02/11 03:04 AM
NW Chicago suburban area
Mopar Mitch Offline OP
Anyone know what the purpose of the 6/32" soft brass plug is that PROMAX supplies with their six pack center carb metering block? Is it critical? Tonight I've had trouble making it fit into the carb -- hex wrench stripped the center hole of the plug, so now the plug is barely into the carb unit and hanging out rather than fully seated. I think its for the blocking of the vacuum advance port from the carb. Can it be epoxied/closed if I cut it off? Thanks ahead to anyone who can help (I'll try PROMAX Sat morning).
Mopar Mitch
Re: PROMAX SIX PACK 6/32" PLUG [Re: Mopar Mitch] #1024288
07/02/11 10:04 AM
07/02/11 10:04 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Call promax
Re: PROMAX SIX PACK 6/32" PLUG [Re: gtx69] #1024289
07/02/11 01:52 PM
07/02/11 01:52 PM
I called Proamx sat morng... no answer... left message.... i'm stuck for now til i get an answer on that plug... I know its used for a vacumm from the missing dist advance tube from the new metering block... its the lower left carb hole just to the right of the lower left bolt hole.
thanks
Re: PROMAX SIX PACK 6/32" PLUG [Re: Mopar Mitch] #1024290
07/02/11 08:07 PM
07/02/11 08:07 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Closed till tuesday
Re: PROMAX SIX PACK 6/32" PLUG [Re: Mopar Mitch] #1024291
07/03/11 12:08 AM
07/03/11 12:08 AM
NY
W
WICKD6PK Offline
WICKD6PK  Offline
W
NY
I have that metering block...never came.with no plug...make sure you have the right block...i did get a wrong block first time around...just sayin
Re: PROMAX SIX PACK 6/32" PLUG [Re: WICKD6PK] #1024292
07/03/11 02:36 AM
07/03/11 02:36 AM
Thanks for the tip on the proper metering block, and the questionable plug.
Re: PROMAX SIX PACK 6/32" PLUG [Re: Mopar Mitch] #1024293
07/06/11 05:37 PM
07/06/11 05:37 PM
I finally spoke with Ben at Promax... he said the plug is rarely needed only when the carb hole happens to be mis-located... and mine is OK... plug not needed! (they should've said this on their info sheet and it would've saved me the time delay). Issue closed!
