Re: Indy SRs...
[Re: tboomer]
#1023861
07/01/11 10:43 AM
07/01/11 10:43 AM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
440 with stock crank, 12.5 compression, small roller cam, minor port work on SR's, single dominator had me in the high 9's.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
Re: Indy SRs...
[Re: tboomer]
#1023863
07/01/11 10:47 AM
07/01/11 10:47 AM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
-4.350 bore -3.75 stroke eagle crank -Eagle rods -Ross 99501 pistons -Pro-Gram main caps/Studs -Indy SR`s Flow 340.3 @.700 -Indy 440-3 intake manifold(OOTB) -Pro Systems Dominator -13.4CR -HS 1.6 rockers -roller cam, 275/282 @ .050, .700/.700 with 1.6RR, 108lsa -CRT Pro-Race 727 -8" Converter freshened by UCC -4.30 Gear -Race weight 3354lbs
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Indy SRs...
[Re: tboomer]
#1023866
07/01/11 11:37 AM
07/01/11 11:37 AM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Who has them and what do you have them on? Combos and ets,please...Thanks!! Ted
Hi Ted I have a set on the self. Right now they are In The Boxes=(pretty slow) My combo is waiting til next year. My ET is 9.44 with MP stage VI's. Going to swap them over the winter, should be just heads and intake swap! Can't wait to see what the difference is. Don
Re: Indy SRs...
[Re: tboomer]
#1023868
07/01/11 05:06 PM
07/01/11 05:06 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
67 Coronet 3480 lbs 14:1 comp small roller Runs 9.60's
Re: Indy SRs...
[Re: tboomer]
#1023869
07/01/11 05:36 PM
07/01/11 05:36 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
I have a set of the SR (M.W. ports, no extra porting that I know of, they flow 340 at .700 on a super Flow 600 bench)that are on my 518 C.I. pump gas low deck stroker now. The car weighs right at 3450 lbs. with me in it, best so far with the Indy 400-2 intake and Holley 850 D.P.(#4781-7)with a 1.5 phenloic spacer is 10.31 on the brakes and the best MPH the same day off of the brakes was 129.72. I do run a set of T&D rockers that are 1.65 ratio on a .420 lobe lift solid roller cam. That is on Oregon pump gas with the air cleaner and exhaust system on I'm going to switch the intake and carb. to a Indy 400-3 with a 1.5 inch cloverleaf spacer and a Holley 1050 dominator, probally remove the exhaust also to put a set of taller tires on it to hold the "extra power", I hope
Re: Indy SRs...
[Re: Cab_Burge]
#1023870
07/01/11 06:04 PM
07/01/11 06:04 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Have you given any thought to the 440-1 heads? They should be fine OTB and you would have room for improvement in the future. A lot of people on here run the SR heads and like them,but 98% of them have spent big $$$$ in having them ported.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: Indy SRs...
[Re: tboomer]
#1023873
07/02/11 09:46 AM
07/02/11 09:46 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I've got a pair of SRs on my 11.5:1, .564"/.564" 251/257 flat tappet cam, Indy dual-plane, Holley 850 DP, .055" over 440. I'm happy with the heads, but just know in advance: if you're putting them on an RB block, you're probably going to have to buy a set of super-expensive (but super-nice) TTI step headers made for the SR heads. I believe that Hedman used to also make headers that would work with the SRs. Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Indy SRs...
[Re: 1968RR]
#1023874
07/02/11 10:39 AM
07/02/11 10:39 AM
Posts: 567 Sth.IL
dare_dude
Sth.IL
Glad to see this post. I have a set I'am getting ready to put on 500/511 motor (still in the works) trying to decide how far to go with them. I only want to go low tens. I have a friend who has his maxed out MW fully ported they look nice and do the job for him. Did any of you change out springs and retainers?
Re: Indy SRs...
[Re: DaKuda]
#1023876
07/02/11 11:21 AM
07/02/11 11:21 AM
Posts: 42 England
pete walton
England
Indy sr650,max wedge stage 2 port job buy Indy,493 cuin,13.5 compression,,, custom ground roller 690 lift,1.6 rockers,,,,,,Seems to work just fine,and reliable...
Re: Indy SRs...
[Re: pete walton]
#1023877
07/02/11 04:15 PM
07/02/11 04:15 PM
MRMOPAR622
Sweet Home Alabama
I had a 451 (.060 over 440)Comp. Cams roller 286/750 with ported&polished 915 heads,12-1 lighten Speed-Pro pistons,D-C Hi-Perf. rods&3.75 crank(mid 80's build) done by some big time Mopar guys.Put a set of OTB 440-1 heads & picked up 100 HP on the dyno.All work & dyno done by the Barnetts. I don't think the SR's or EZ's will do that. I know a few people who run both heads and have put a lot of $$$ into them in port work and they do run good.But they have now invested as much as a set of 440-1's which would be faster cost.
Re: Indy SRs...
[Re: steeldust]
#1023879
07/03/11 09:16 AM
07/03/11 09:16 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Ted, What is your 60', ET, & MPH now,,,, What ET number you shooting for Car looks good,,,
