Indy SRs... #1023860
07/01/11 10:21 AM
07/01/11 10:21 AM
tboomer Offline OP
tboomer  Offline OP
Who has them and what do you have them on? Combos and ets,please...Thanks!! Ted
Re: Indy SRs... [Re: tboomer] #1023861
07/01/11 10:43 AM
07/01/11 10:43 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
440 with stock crank, 12.5 compression, small roller cam, minor port work on SR's, single dominator had me in the high 9's.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Indy SRs... [Re: nhramark] #1023862
07/01/11 10:44 AM
07/01/11 10:44 AM
tboomer Offline OP
tboomer  Offline OP
Pretty impressive,Mark! Hows it going down your way?
Re: Indy SRs... [Re: tboomer] #1023863
07/01/11 10:47 AM
07/01/11 10:47 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
-4.350 bore
-3.75 stroke eagle crank
-Eagle rods
-Ross 99501 pistons
-Pro-Gram main caps/Studs
-Indy SR`s Flow 340.3 @.700
-Indy 440-3 intake manifold(OOTB)
-Pro Systems Dominator
-13.4CR
-HS 1.6 rockers
-roller cam, 275/282 @ .050, .700/.700 with 1.6RR, 108lsa
-CRT Pro-Race 727
-8" Converter freshened by UCC
-4.30 Gear
-Race weight 3354lbs
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Indy SRs... [Re: tboomer] #1023864
07/01/11 10:57 AM
07/01/11 10:57 AM
Denmark
Dart of Denmark Offline
Denmark
511cui SR head with phase 3 port by hensley.
ET: 9.10 3200lbs.
Re: Indy SRs... [Re: tboomer] #1023865
07/01/11 11:03 AM
07/01/11 11:03 AM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
We are all out of racetracks here, so spending a lot more time in the pool.
Re: Indy SRs... [Re: tboomer] #1023866
07/01/11 11:37 AM
07/01/11 11:37 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Hi Ted I have a set on the self.
Right now they are In The Boxes=(pretty slow)
My combo is waiting til next year.
My ET is 9.44 with MP stage VI's.
Going to swap them over the winter, should be just heads and intake swap! Can't wait to see what the difference is.
Don
Re: Indy SRs... [Re: cudadon] #1023867
07/01/11 11:46 AM
07/01/11 11:46 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,guys! Don...My Stage VIs are the 383-440 street heads..I don't know how the chambers compare to the ones you have...Maybe Zippy could chime in and explain or Dwayne Porter..I think mine are a good enough head but they probably don't get enough air thru them for my cubic inches..So I am now standing at the crossroads.. Spend money later this year on SRs. or get my current ones worked over..
Re: Indy SRs... [Re: tboomer] #1023868
07/01/11 05:06 PM
07/01/11 05:06 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
67 Coronet 3480 lbs 14:1 comp small roller Runs 9.60's
Re: Indy SRs... [Re: tboomer] #1023869
07/01/11 05:36 PM
07/01/11 05:36 PM
I have a set of the SR (M.W. ports, no extra porting that I know of, they flow 340 at .700 on a super Flow 600 bench)that are on my 518 C.I. pump gas low deck stroker now. The car weighs right at 3450 lbs. with me in it, best so far with the Indy 400-2 intake and Holley 850 D.P.(#4781-7)with a 1.5 phenloic spacer is 10.31 on the brakes and the best MPH the same day off of the brakes was 129.72. I do run a set of T&D rockers that are 1.65 ratio on a .420 lobe lift solid roller cam. That is on Oregon pump gas with the air cleaner and exhaust system on I'm going to switch the intake and carb. to a Indy 400-3 with a 1.5 inch cloverleaf spacer and a Holley 1050 dominator, probally remove the exhaust also to put a set of taller tires on it to hold the "extra power", I hope
Re: Indy SRs... [Re: Cab_Burge] #1023870
07/01/11 06:04 PM
07/01/11 06:04 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Have you given any thought to the 440-1 heads? They should be fine OTB and you would have room for improvement in the future.
A lot of people on here run the SR heads and like them,but 98% of them have spent big $$$$ in having them ported.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Indy SRs... [Re: MRMOPAR622] #1023871
07/01/11 06:07 PM
07/01/11 06:07 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
what about some indy EZ heads? that way ted would not have to change his headers or rockers. sorry if it was a dumb question.Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Indy SRs... [Re: mopar65] #1023872
07/02/11 09:06 AM
07/02/11 09:06 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,guys...Cab.That is about the same roller I have. The SRs.take the rocker assembly in the same location as stock,don't they? I do see that there are -1s for sale on racing junk. Bobby...Guess I haven't given any thought to the EZs..That could be another option. You know I always welcome your imput!! I won't do anything this year. Just getting some opinions!! Thanks!! Ted
Re: Indy SRs... [Re: tboomer] #1023873
07/02/11 09:46 AM
07/02/11 09:46 AM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I've got a pair of SRs on my 11.5:1, .564"/.564" 251/257 flat tappet cam, Indy dual-plane, Holley 850 DP, .055" over 440. I'm happy with the heads, but just know in advance: if you're putting them on an RB block, you're probably going to have to buy a set of super-expensive (but super-nice) TTI step headers made for the SR heads. I believe that Hedman used to also make headers that would work with the SRs.
Good luck.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Indy SRs... [Re: 1968RR] #1023874
07/02/11 10:39 AM
07/02/11 10:39 AM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Glad to see this post. I have a set I'am getting ready to put on 500/511 motor (still in the works) trying to decide how far to go with them. I only want to go low tens. I have a friend who has his maxed out MW fully ported they look nice and do the job for him. Did any of you change out springs and retainers?
Re: Indy SRs... [Re: MRMOPAR622] #1023875
07/02/11 10:59 AM
07/02/11 10:59 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I disagree. I have had both. My SR'S were done by Marsh Performance and are awesome. If I had to do it all over after having both I would take the SR again. In the end the gains were not that great with the -1 unless its an all out effort.
Re: Indy SRs... [Re: DaKuda] #1023876
07/02/11 11:21 AM
07/02/11 11:21 AM
England
P
pete walton Offline
pete walton  Offline
P
England
Indy sr650,max wedge stage 2 port job buy Indy,493 cuin,13.5 compression,,, custom ground roller 690 lift,1.6 rockers,,,,,,Seems to work just fine,and reliable...
Re: Indy SRs... [Re: pete walton] #1023877
07/02/11 04:15 PM
07/02/11 04:15 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I had a 451 (.060 over 440)Comp. Cams roller 286/750 with ported&polished 915 heads,12-1 lighten Speed-Pro pistons,D-C Hi-Perf. rods&3.75 crank(mid 80's build) done by some big time Mopar guys.Put a set of OTB 440-1 heads & picked up 100 HP on the dyno.All work & dyno done by the Barnetts. I don't think the SR's or EZ's will do that. I know a few people who run both heads and have put a lot of $$$ into them in port work and they do run good.But they have now invested as much as a set of 440-1's which would be faster cost.
Re: Indy SRs... [Re: MRMOPAR622] #1023878
07/03/11 01:56 AM
07/03/11 01:56 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I have a set of 440-1s out of the box and my headers that was on my stock 452 heads they work just fine they bolted right up and i got my heads from MANCINI THEY HAD THE BEST PRICES and good service and they are good people and will help you. good luck
Re: Indy SRs... [Re: steeldust] #1023879
07/03/11 09:16 AM
07/03/11 09:16 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Ted,
What is your 60', ET, & MPH now,,,,
What ET number you shooting for
Car looks good,,,
