Best Lo Deck Intake for Stock Ports M1? Victor? Other? #1022827
06/29/11 05:15 PM
06/29/11 05:15 PM
Anonymous OP
Anonymous OP
What 4150 flange intake will make the most HP? Lo deck Eddy heads solid cam drag style engine --NO Dom--4150 style Are there any tests that have been done you know of? Who knows which SP intake has the greatest volume. Thanks!
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: ] #1022828
06/29/11 05:48 PM
06/29/11 05:48 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
One of the Mopar magazines (I believe) did the manifold tests on a low deck with ported Edelbrock's and a pretty healthy solid cam. It was reran in the last Engine Masters magazine.
The best all around single plane was the Victor,and the M1 was almost identicle. They actually made the best overall torque and horsepower with a tunnel ram.
You might be able to look at the article on Engine Master's website?
Keith
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: Dunnuck Racing] #1022829
06/29/11 07:35 PM
06/29/11 07:35 PM
dogdays Offline
dogdays  Offline
4-5 years ago the best stock port B engine 4150-style intake was the Edelbrock TM-6. Maybe the Victor is better, but there weren't any MP intakes that could rumn with a TM-6.
Have things changed that much?
R.
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: dogdays] #1022830
06/29/11 07:55 PM
06/29/11 07:55 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
I've used the M1 and the TM-6 (with a 1" four hole on top of a 1" open spacer arrangement) on the same engine and the TM-6 was about .05 better on the track for me . I haven't tried a victor though.
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: ] #1022831
06/29/11 09:46 PM
06/29/11 09:46 PM
AndyF Offline
AndyF  Offline
Best intake is the 4500 version of the M1. Then use a Wilson adapter to go from the 4500 flange to the 4150 flange.
The Victor 383 is a good intake but the plenum is kind of small. The 4500 M1 looks like a better plenum design and it makes more hp on dyno tests that I've run.
There aren't a lot of good choices for the low deck with std ports. Most of the intakes are old designs that won't make much power.
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: dogdays] #1022832
06/29/11 10:03 PM
06/29/11 10:03 PM
NC
440Jim Offline
440Jim  Offline
NC
Back when I ran the Edelbrock RPM heads with porting on my 451 CID low deck, a ported TM-6 was better than the M1 low deck intake. And I even tried the low deck M1 "popsicle stick" distribution modification. This was with a 272/280 at 0.050" cam and about 12.2 CR. That ported TM-6 was awesome. It needed the tight turn on the "inner" cyliders (3,5, 2,4) ported.
Here are the port dimensions (attached).
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: 440Jim] #1022833
06/29/11 10:04 PM
06/29/11 10:04 PM
NC
440Jim Offline
440Jim  Offline
NC
And here are some flow numbers on a Superflow 100? (small one). And the track performance confirmed the flow bench improvement.
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: ] #1022834
06/29/11 10:13 PM
06/29/11 10:13 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'll agree on the TM-6..it's a VERY good intake.We've had one since 1972.
Nautilus Racing-
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: ] #1022835
06/30/11 01:26 AM
06/30/11 01:26 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I ran the M1 4150 flange intake with a 1" open spacer on my 451 stroked 400 and it worked good for me. I'll sell it for $150. It's been sitting around the garage since the new engine has max wedge ports and indy intake.
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: 440Jim] #1022836
06/30/11 11:06 AM
06/30/11 11:06 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yep, from my lil' SF110 w/ correction factors applied.
Jeez, you are still quite the Data God, aren't you? /
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: BradH] #1022837
06/30/11 11:12 AM
06/30/11 11:12 AM
Hudson N.H.
b1596 Offline
b1596  Offline
Hudson N.H.
I have a TM6 and ill never use it ,if any one wants it let me know....
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other? [Re: BradH] #1022838
06/30/11 09:37 PM
06/30/11 09:37 PM
NC
440Jim Offline
440Jim  Offline
NC
When I saw the 2002 date on that file, it amazed me too (9 years).
That ported intake was awesome in that application. When I went to a bigger engine and max wedge heads, the Indy single plane was perfect for drag racing, but I really noticed how bad it was driving in the pits compared to the TM-6.
