Best Lo Deck Intake for Stock Ports M1? Victor? Other?
#1022827
06/29/11 05:15 PM
06/29/11 05:15 PM
What 4150 flange intake will make the most HP? Lo deck Eddy heads solid cam drag style engine --NO Dom--4150 style Are there any tests that have been done you know of? Who knows which SP intake has the greatest volume. Thanks!
Re: Best Lo Deck Intake for Stock Ports M1? Victor? Other?
[Re: ]
#1022831
06/29/11 09:46 PM
06/29/11 09:46 PM
Posts: 31,077 Oregon
AndyF
Best intake is the 4500 version of the M1. Then use a Wilson adapter to go from the 4500 flange to the 4150 flange.
The Victor 383 is a good intake but the plenum is kind of small. The 4500 M1 looks like a better plenum design and it makes more hp on dyno tests that I've run.
There aren't a lot of good choices for the low deck with std ports. Most of the intakes are old designs that won't make much power.
[Re: ]
#1022834
06/29/11 10:13 PM
06/29/11 10:13 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I'll agree on the TM-6..it's a VERY good intake.We've had one since 1972.
[Re: 440Jim]
#1022836
06/30/11 11:06 AM
06/30/11 11:06 AM
BradH
And here are some flow numbers on a Superflow 100? (small one). And the track performance confirmed the flow bench improvement.
Yep, from my lil' SF110 w/ correction factors applied.
Jeez, you are still quite the Data God, aren't you? /
[Re: BradH]
#1022838
06/30/11 09:37 PM
06/30/11 09:37 PM
Posts: 16,932 NC
440Jim
NC
When I saw the 2002 date on that file, it amazed me too (9 years).
That ported intake was awesome in that application. When I went to a bigger engine and max wedge heads, the Indy single plane was perfect for drag racing, but I really noticed how bad it was driving in the pits compared to the TM-6.
