Re: CARB WHISTLES
[Re: rickb67]
#1021783
06/28/11 09:30 AM
06/28/11 09:30 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
adjust the rear throttle blades a little
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: CARB WHISTLES
[Re: rickb67]
#1021784
06/28/11 11:48 AM
06/28/11 11:48 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Did you make a pass with the e-85? Did it run any better?
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: CARB WHISTLES
[Re: MIKES_DUSTER]
#1021790
06/28/11 06:02 PM
06/28/11 06:02 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Do you know why its whistling??? Because it doesnt know the words!!!! HAHAHAHA!!!!!!
I had to chuckle at this one. It sure sounds like a vacuum leak to me......but if carb clean didn't find it ![](/ubbthreads/images/graemlins/shruggy.gif) It wasn't the environmentally friendly non flammable stuff that won't remove dust carb cleaner , was it ?
Re: CARB WHISTLES
[Re: sixpackgut]
#1021794
06/29/11 06:58 PM
06/29/11 06:58 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
had similar situation .1 of the mixture screw washers/seals,cork type,had shrunk.screw backed out . must of sucked there.replaced the mixture screw seal,reset mixture - whistle gone
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
