CARB WHISTLES #1021782
06/28/11 02:24 AM
06/28/11 02:24 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Had an 850 converted to E85 finally got to the track on sunday.Had my regular gas carb on for first pass ran fine. Put the E85 carb on drained the race gas and filled it with E85.Had a whistle in the carb thought it was a vacumn leak. We sprayed it down with starting fluid could not find it. You can hear it coming thru the pits even.I can hold my hand over the right venturies and it will kind of block the sound.
Re: CARB WHISTLES [Re: rickb67] #1021783
06/28/11 09:30 AM
06/28/11 09:30 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
adjust the rear throttle blades a little
Re: CARB WHISTLES [Re: rickb67] #1021784
06/28/11 11:48 AM
06/28/11 11:48 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Did you make a pass with the e-85? Did it run any better?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: CARB WHISTLES [Re: 1967dartgt] #1021785
06/28/11 02:21 PM
06/28/11 02:21 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Do you know why its whistling??? Because it doesnt know the words!!!! HAHAHAHA!!!!!!
Re: CARB WHISTLES [Re: MIKES_DUSTER] #1021786
06/28/11 03:11 PM
06/28/11 03:11 PM
Colorado Springs, Colorado
Dartthunder340 Offline
Ha,ha! Mikes Duster that made me laugh.
Better get inside Ma. Looks like a storm's comin'.
Re: CARB WHISTLES [Re: Dartthunder340] #1021787
06/28/11 03:40 PM
06/28/11 03:40 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Its not unusual for these old cars to whistle past the the junkyard.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: CARB WHISTLES [Re: Dartthunder340] #1021788
06/28/11 05:20 PM
06/28/11 05:20 PM
Sorry but I had to say it!!!!! LOL
Re: CARB WHISTLES [Re: rickb67] #1021789
06/28/11 05:54 PM
06/28/11 05:54 PM
Did you plug the inlet(if it has one) on the rear of the carb for the PCV
Re: CARB WHISTLES [Re: MIKES_DUSTER] #1021790
06/28/11 06:02 PM
06/28/11 06:02 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I had to chuckle at this one.
It sure sounds like a vacuum leak to me......but if carb clean didn't find it
It wasn't the environmentally friendly non flammable stuff that won't remove dust carb cleaner , was it ?
Re: CARB WHISTLES [Re: 1967dartgt] #1021791
06/29/11 02:19 AM
06/29/11 02:19 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Yes i did make a several passes on E85. It hasn't made a difference yet. The track sunday was terrible. Mike that made me laugh to . All ports are plugged.do i open the rear throttle plates or close them.
Re: CARB WHISTLES [Re: rickb67] #1021792
06/29/11 08:14 AM
06/29/11 08:14 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The few times I've had a whistle, it leaked at the base plate.
Re: CARB WHISTLES [Re: rickb67] #1021793
06/29/11 09:05 AM
06/29/11 09:05 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i would try opening them just a bit. it sucks to do with stock holleys because it may still be there. one of my outboards whistles at certain spot but i can adjust them with them on the car.
Re: CARB WHISTLES [Re: sixpackgut] #1021794
06/29/11 06:58 PM
06/29/11 06:58 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
had similar situation .1 of the mixture screw washers/seals,cork type,had shrunk.screw backed out .
must of sucked there.replaced the mixture screw seal,reset mixture - whistle gone
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
