Re: Big block stroker kits???
[Re: supercomp]
#1014261
06/16/11 02:59 PM
06/16/11 02:59 PM
Posts: 2,091 Delray beach, Florida
Performance Only
I would rather get one from a high end shop like Dan ( performance only ) it will be RIGHT, you can bet on it.
thank you, i appreciate the kind words. we sell all sorts of kits and we fix all the problems so the customer isn't left with balance problems, clearance issues, etc. i've redone a bunch of supposedly checked and balanced kits and so far they all needed work to make them right. i've seen all sorts of issues, like out of round rods, pins that don't fit the rod small end, balance that's not even close, etc. it always amazes me what some places sell as "ready to run" kits. we see some of the results posted on this site every so often, often times with broken rods, burn't crank journals and so on. you generally get what you pay for when it comes to engine parts. often times a cheap selling price just equates to more work needing to be done for the parts to survive long term. some get lucky, some don't, unfortunately.
machine shop owner and engine builder
[Re: Performance Only]
#1014262
06/16/11 05:21 PM
06/16/11 05:21 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I used a eagle kit with eagle rods and srp pistons. The rods needed a little work on the small end but the balance was right on! They actually paid to have them fixed. I used 440 source main caps and they needed alot of work to fit but other then that it worked out real good.
67' charger 499 RB
10.57 at 127
#1014263
06/16/11 06:24 PM
06/16/11 06:24 PM
Posts: 610 long time lurker, short time p...
PorkyPig
Scary, but true.
[Re: ChallengerRTSE]
#1014264
06/16/11 11:20 PM
06/16/11 11:20 PM
Posts: 12,070 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
When I bought my Ohio Crank stroker kit a few years ago, everything checked okay. Except the rod bearings. They were too wide, and Ohio overnighted the narrower ones. I have run this set-up for 6 years now.
It goes without saying that we should have everything checked. But I don't agree that we should expect to fix stuff. Things can get by the vendors, but I would hope that we shouldn't come to expect it. At least not of the better suppliers.
Master, again and still
[Re: 493_DART]
#1014266
06/17/11 02:12 AM
06/17/11 02:12 AM
Posts: 469 Tennessee
steeldust
Tennessee
Ive ran the 440 Source kit since about 2007 with no issues . Believe me , it gets beat on all summer.
I got a 440 Source kit for a 572 the pistons was OK and the Rods had to be honed to fit the pins but OK the bearing and rings was OK the crank would run but i had it rebalanced and i would buy a kit from them again i have not run it a lot but it"s OK right now but if you get a kit get it checked are you could be sorry and good luck .
[Re: steeldust]
#1014267
06/17/11 02:52 AM
06/17/11 02:52 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I agree-- had mine all checked out by a machinist--all he had to do was hone for the pins.
#1014268
06/17/11 06:36 AM
06/17/11 06:36 AM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Mancini also sells that kit in an "unbalanced" form.
If the components are all a known competitive brand and price is comparable........why not buy it and have the pieces double checked and balanced by a reliable machinist??
[Re: Dean_Kuzluzski]
#1014269
06/17/11 07:03 AM
06/17/11 07:03 AM
Quicktree
wouldn't it be easier and probably cheaper to pick up the phone and make one call? have it delivered to your door ready to go?
[Re: PorkyPig]
#1014270
06/17/11 08:16 AM
06/17/11 08:16 AM
steeldust
Tennessee
Scary, but true.
100% true if your smart have it checked he is right because it could be OK but what if it"s not after the trouble i have had if it don"t get checked it don"t get put together any kit.Good luck.
