Big block stroker kits??? #1014255
06/16/11 12:00 PM
06/16/11 12:00 PM
Odessa, Tejas
ChallengerRTSE Offline OP
Odessa, Tejas
I am in the market for a complete balanced stroker kit for my 440. After looking around I see Mancini offers on balanced for $1750 on their website. It looks like a eagle crank/rods with Diamond pistons. Has anyone purchased this kit??
Re: Big block stroker kits??? [Re: ChallengerRTSE] #1014256
06/16/11 12:09 PM
06/16/11 12:09 PM
Which part number kit
Re: Big block stroker kits??? [Re: Cab_Burge] #1014257
06/16/11 12:27 PM
06/16/11 12:27 PM
Odessa, Tejas
Odessa, Tejas
Here's the part number off the webb site
MRE440-493KIT-FLAT-BAL
Re: Big block stroker kits??? [Re: ChallengerRTSE] #1014258
06/16/11 01:02 PM
06/16/11 01:02 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
IMHO I would never buy a pre-balanced kit from anyone, for the same reason I wouldn't buy a kit and trust the fit and finish was as advertised. As my machinist buddy says "if it comes out of a box, it's #$%&ed up no matter who built it"
As for the parts themselves, the crank and rods are Chinese and one brand is pretty much as good as another once they are properly checked and corrected. I would buy the unbalanced kit, take it to a machinist that knows what he's doing (good luck with that) and have it balanced AFTER all the parts are checked and corrected.
Kevin
Re: Big block stroker kits??? [Re: Twostick] #1014259
06/16/11 01:17 PM
06/16/11 01:17 PM
Odessa, Tejas
Odessa, Tejas
Good point on the balancing. I hadn't thought about that!
Re: Big block stroker kits??? [Re: ChallengerRTSE] #1014260
06/16/11 02:04 PM
06/16/11 02:04 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I would rather get one from a high end shop like Dan ( performance only ) it will be RIGHT, you can bet on it.
Re: Big block stroker kits??? [Re: supercomp] #1014261
06/16/11 02:59 PM
06/16/11 02:59 PM
Delray beach, Florida
P
Performance Only Offline
P
thank you, i appreciate the kind words. we sell all sorts of kits and we fix all the problems so the customer isn't left with balance problems, clearance issues, etc.
i've redone a bunch of supposedly checked and balanced kits and so far they all needed work to make them right. i've seen all sorts of issues, like out of round rods, pins that don't fit the rod small end, balance that's not even close, etc. it always amazes me what some places sell as "ready to run" kits.
we see some of the results posted on this site every so often, often times with broken rods, burn't crank journals and so on. you generally get what you pay for when it comes to engine parts. often times a cheap selling price just equates to more work needing to be done for the parts to survive long term. some get lucky, some don't, unfortunately.
machine shop owner and engine builder
Re: Big block stroker kits??? [Re: Performance Only] #1014262
06/16/11 05:21 PM
06/16/11 05:21 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I used a eagle kit with eagle rods and srp pistons. The rods needed a little work on the small end but the balance was right on! They actually paid to have them fixed. I used 440 source main caps and they needed alot of work to fit but other then that it worked out real good.
67' charger 499 RB 10.57 at 127
Re: Big block stroker kits??? [Re: Performance Only] #1014263
06/16/11 06:24 PM
06/16/11 06:24 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Scary, but true.
Re: Big block stroker kits??? [Re: ChallengerRTSE] #1014264
06/16/11 11:20 PM
06/16/11 11:20 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
When I bought my Ohio Crank stroker kit a few years ago, everything checked okay. Except the rod bearings. They were too wide, and Ohio overnighted the narrower ones. I have run this set-up for 6 years now.
It goes without saying that we should have everything checked. But I don't agree that we should expect to fix stuff. Things can get by the vendors, but I would hope that we shouldn't come to expect it. At least not of the better suppliers.
Master, again and still
Re: Big block stroker kits??? [Re: DaveRS23] #1014265
06/17/11 12:47 AM
06/17/11 12:47 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Ive ran the 440 Source kit since about 2007 with no issues . Believe me , it gets beat on all summer.
Re: Big block stroker kits??? [Re: 493_DART] #1014266
06/17/11 02:12 AM
06/17/11 02:12 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I got a 440 Source kit for a 572 the pistons was OK and the Rods had to be honed to fit the pins but OK the bearing and rings was OK the crank would run but i had it rebalanced and i would buy a kit from them again i have not run it a lot but it"s OK right now but if you get a kit get it checked are you could be sorry and good luck .
Re: Big block stroker kits??? [Re: steeldust] #1014267
06/17/11 02:52 AM
06/17/11 02:52 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I agree-- had mine all checked out by a machinist--all he had to do was hone for the pins.
Re: Big block stroker kits??? [Re: ChallengerRTSE] #1014268
06/17/11 06:36 AM
06/17/11 06:36 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Mancini also sells that kit in an "unbalanced" form.
If the components are all a known competitive brand and price is comparable........why not buy it and have the pieces double checked and balanced by a reliable machinist??
Re: Big block stroker kits??? [Re: Dean_Kuzluzski] #1014269
06/17/11 07:03 AM
06/17/11 07:03 AM
Q
Quicktree Offline
Quicktree  Offline
Q
wouldn't it be easier and probably cheaper to pick up the phone and make one call? have it delivered to your door ready to go?
Re: Big block stroker kits??? [Re: PorkyPig] #1014270
06/17/11 08:16 AM
06/17/11 08:16 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
Scary, but true.
100% true if your smart have it checked he is right because it could be OK but what if it"s not after the trouble i have had if it don"t get checked it don"t get put together any kit.Good luck.
Re: Big block stroker kits??? [Re: steeldust] #1014271
06/17/11 09:44 AM
06/17/11 09:44 AM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Check with Nick at Comp U Flow
