Drag Radials...Are you putting screws in them??? #1013883
06/15/11 03:55 PM
06/15/11 03:55 PM
IN
Dartman928 Offline OP
IN
Just curious how many guys are running drag radials and putting screws in them to the rim?
Thanks for the input
I picked up a new set of 295/55R15 M/T for the dart can't wait to try them out
Re: Drag Radials...Are you putting screws in them??? [Re: Dartman928] #1013884
06/15/11 04:30 PM
06/15/11 04:30 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Tubes & Screws for me
Re: Drag Radials...Are you putting screws in them??? [Re: RATTRAP] #1013885
06/15/11 04:32 PM
06/15/11 04:32 PM
IN
IN
How fast you going?
Re: Drag Radials...Are you putting screws in them??? [Re: RATTRAP] #1013886
06/15/11 04:34 PM
06/15/11 04:34 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
you should NOT have a tube in drag radials, i used to run screws but have not in a long time now. I glue them on with the loctite red gasket glue and thats it.....yes they move a lil and usually take a set after moving about 1/4 of the way around, but thats after about 30+ passes
....BAD A$$ STREET CAR.....
Re: Drag Radials...Are you putting screws in them??? [Re: n20mstr] #1013887
06/15/11 04:36 PM
06/15/11 04:36 PM
Ma
Voluster Offline
Voluster  Offline
Ma
No Tubes and No screws here
I don't even glue them
been 1.37 60 on a 275DR
Re: Drag Radials...Are you putting screws in them??? [Re: Voluster] #1013888
06/15/11 04:51 PM
06/15/11 04:51 PM
detroit area
moderncylinder Offline
detroit area
because the additional pressure you run in a radial tire as compared to a bias-ply,, you do not need to screw them into the rim, the added pressure helps to keep the tire seated to the rim
Re: Drag Radials...Are you putting screws in them??? [Re: n20mstr] #1013889
06/15/11 05:14 PM
06/15/11 05:14 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Says Who, I havent had and prob with this setup as of yet,tires dont break loose on the rim and no pressure loss,U can run a slick with out tubes but why would you, If there is a reason to not tube besides u dont need to I would like to no why.If u ask me its redundancy to have tubes, Im pushing 650hp in a 68 B body.
Re: Drag Radials...Are you putting screws in them??? [Re: RATTRAP] #1013890
06/15/11 05:42 PM
06/15/11 05:42 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
no tubes or screws here.
Mopar Performance
Re: Drag Radials...Are you putting screws in them??? [Re: moparniac] #1013891
06/15/11 05:53 PM
06/15/11 05:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
No screws or tubes here, I'm not very fast though, 325s, have been 1.38 60' at 3260#. Ny tires moved a little the first couple times but have not moved since.
Re: Drag Radials...Are you putting screws in them??? [Re: Dartman928] #1013892
06/15/11 06:27 PM
06/15/11 06:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Nothing on my DR on the Rampage
Re: Drag Radials...Are you putting screws in them??? [Re: MR_P_BODY] #1013893
06/15/11 06:41 PM
06/15/11 06:41 PM
baldwinsville new york
a493demon Online content
a493demon  Online Content
there s a good post on yb about that.
Re: Drag Radials...Are you putting screws in them??? [Re: a493demon] #1013894
06/15/11 07:45 PM
06/15/11 07:45 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I'm not running "drag radials", as in street legal tires, but I'm running a radial slick. 32-13.60 x 15 phoenix on a 15 x 14 rim.
I run 16.5-17 lbs. No tubes, no screws.
3550 race weight, best of 1.39 60', 9.92 @ 135.
Tires have moved maybe an inch since I put them on 2 yrs ago.
Re: Drag Radials...Are you putting screws in them??? [Re: G_bob] #1013895
06/15/11 08:19 PM
06/15/11 08:19 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Nope.. no screws no tubes... 275-60-15, 3500 lbs, 10.52 @ 125
14-15 lbs air
Re: Drag Radials...Are you putting screws in them??? [Re: Jeepmon] #1013896
06/15/11 08:55 PM
06/15/11 08:55 PM
MN
hemidup Offline
hemidup  Offline
MN
No tubes, no screws. 5184 lbs cutting 1.48 60's.
Jerry Williams.
Re: Drag Radials...Are you putting screws in them??? [Re: hemidup] #1013897
06/15/11 08:58 PM
06/15/11 08:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
No Tubes, No Screws, 750+ runs.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Drag Radials...Are you putting screws in them??? [Re: Triple Threat] #1013898
06/15/11 09:19 PM
06/15/11 09:19 PM
IN
IN
So if the tires do turn some on the rim shouldnt you get them rebalanced?
Re: Drag Radials...Are you putting screws in them??? [Re: Dartman928] #1013899
06/15/11 09:23 PM
06/15/11 09:23 PM
Renton Washington
Renton Washington
Mine have never turned, but the car isn't fast. If they turned enough to cause vibration, which I doubt will happen then sure, rebalance them. Lots of tire shops have lifetime balancing
-Dustin
Re: Drag Radials...Are you putting screws in them??? [Re: Triple Threat] #1013900
06/15/11 11:27 PM
06/15/11 11:27 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I was on the Bullet looking at what they were doing with theirs before I bought mine, and they were glueing them, so that's what I did. I did have an issue with the tire rotating in the rim once glued, just lack of any real traction.
They are not slicks, and I am now sure after running a set, they do not repeat like slicks and are not great for bracket racing. But if you have a fast street car and they are required for your class, by all means run them. I thought they would be a great dual purpose tire, but I don't like going thru the traps sideways at triple digit speeds.
Re: Drag Radials...Are you putting screws in them??? [Re: Dartman928] #1013901
06/15/11 11:32 PM
06/15/11 11:32 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I have bougth a set of 295 65 15 and mounted them on a 8 inch rim
is this good or would a 10 inch rim be better
1.39 9.85 - 137 mph
Re: Drag Radials...Are you putting screws in them??? [Re: Dragula] #1013902
06/15/11 11:42 PM
06/15/11 11:42 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What the he__ do you run them on to go sideways throught the traps? Topfuel dragster? Wolf has been 4.20s in the 1/8 straight as a arrow, thats with approx 2500 hp. I can understand that they are not as consistant as slicks off the line but once they are hooked up I have never lost traction with them. I will personaly never run a slick again.
