Re: Drag Radials...Are you putting screws in them???
[Re: RATTRAP]
#1013885
06/15/11 04:32 PM
06/15/11 04:32 PM
Posts: 2,792 IN
Dartman928
IN
Tubes & Screws for me
How fast you going?
[Re: RATTRAP]
#1013886
06/15/11 04:34 PM
06/15/11 04:34 PM
Posts: 4,688 On the parachute mount
n20mstr
you should NOT have a tube in drag radials, i used to run screws but have not in a long time now. I glue them on with the loctite red gasket glue and thats it.....yes they move a lil and usually take a set after moving about 1/4 of the way around, but thats after about 30+ passes
....BAD A$$ STREET CAR.....
[Re: Jeepmon]
#1013896
06/15/11 08:55 PM
06/15/11 08:55 PM
Posts: 833 MN
hemidup
MN
No tubes, no screws. 5184 lbs cutting 1.48 60's.
Jerry Williams.
[Re: Triple Threat]
#1013900
06/15/11 11:27 PM
06/15/11 11:27 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
I was on the Bullet looking at what they were doing with theirs before I bought mine, and they were glueing them, so that's what I did. I did have an issue with the tire rotating in the rim once glued, just lack of any real traction.
They are not slicks, and I am now sure after running a set, they do not repeat like slicks and are not great for bracket racing. But if you have a fast street car and they are required for your class, by all means run them. I thought they would be a great dual purpose tire, but I don't like going thru the traps sideways at triple digit speeds.
[Re: Dartman928]
#1013901
06/15/11 11:32 PM
06/15/11 11:32 PM
Posts: 5,618 long island NY
Ari440
long island NY
I have bougth a set of 295 65 15 and mounted them on a 8 inch rim
is this good or would a 10 inch rim be better
1.39 9.85 - 137 mph
[Re: Dragula]
#1013902
06/15/11 11:42 PM
06/15/11 11:42 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
What the he__ do you run them on to go sideways throught the traps? Topfuel dragster? Wolf has been 4.20s in the 1/8 straight as a arrow, thats with approx 2500 hp. I can understand that they are not as consistant as slicks off the line but once they are hooked up I have never lost traction with them. I will personaly never run a slick again.
