How to remove clutch from RV-2 style A/C compressor? #1013675
06/15/11 09:16 AM
06/15/11 09:16 AM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
Is the clutch pressed on like a harmonic balancer, or should it come off when you remove the one bolt in the center?
69 Chrysler 300 Convertible 77 Chrysler New Yorker Brougham 2-dr 03 Jeep Grand Cherokee Limited
Re: How to remove clutch from RV-2 style A/C compressor? [Re: mantonas] #1013676
06/15/11 09:51 AM
06/15/11 09:51 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
most I've seen there is a 5/16" bolt ( 1/2" hex head ) holding the clutch on.
Remove said bolt and then the clutch is threaded.
I think the threads are something like 5/8"
Just thread the large bolt in and it pulls the clutch off
Re: How to remove clutch from RV-2 style A/C compressor? [Re: gtx6970] #1013677
06/15/11 11:01 AM
06/15/11 11:01 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
What Bill said. The clutch is on a tapered shaft/crank end and you will need to "push" (or pull ) it off with a larger bolt. BTW all of the bolts are right-hand threads....
MikeR
Re: How to remove clutch from RV-2 style A/C compressor? [Re: A12] #1013678
06/15/11 11:06 AM
06/15/11 11:06 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Head to the hardware store and get a bolt (I'll need to get the size and thread pitch, sorry ) and grind the tip like this:
Re: How to remove clutch from RV-2 style A/C compressor? [Re: A12] #1013679
06/15/11 11:09 AM
06/15/11 11:09 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Then with the 1/2" hex head (3/8" bolt dia.?) retaining bolt and washer removed install the larger bolt, hold the clutch and thread in and the larger bolt will push the clutch off of the taper.
MikeR
Re: How to remove clutch from RV-2 style A/C compressor? [Re: A12] #1013680
06/15/11 11:48 AM
06/15/11 11:48 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
on my 74 ( earliers too ) the clutch its pressed in to the bearing, inside the pulley.
the 1/2" hex head bolt in the middle just holds the complete clutch/pulley assembly into the tappered crank shaft
I remember have seen a thread somewhere around though, but had to remmove it with a press. Long time I did that!
Note, my assembly is with the smaller diameter pulley, not the big pulley like 60s models. Maybe there is the difference
Re: How to remove clutch from RV-2 style A/C compressor? [Re: NachoRT74] #1013681
06/15/11 12:27 PM
06/15/11 12:27 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The clutch hub or flywheel has only a few threads in it for the puller and they can appear to make the hub look as if it is threaded onto the crankshaft end (see attachment) but I pretty sure they were all on a taper, at least all of the Mopar A/C RV-2 pumps I've seen so far.
MikeR
Re: How to remove clutch from RV-2 style A/C compressor? [Re: NachoRT74] #1013682
06/15/11 01:51 PM
06/15/11 01:51 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive removed quite a few using my deadblow hammer.I just remove the center nut then tap around the backside of the clutch.Ive never had one that wouldnt come off with some light tapping.One from my Imp sat for probally 10 years in the garage.A few taps and it slid off.Rocky
Chrysler Firepower
Re: How to remove clutch from RV-2 style A/C compressor? [Re: gtx6970] #1013683
06/15/11 03:52 PM
06/15/11 03:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
5/8"-11 to be exact.
Re: How to remove clutch from RV-2 style A/C compressor? [Re: John_Kunkel] #1013684
06/21/11 08:28 AM
06/21/11 08:28 AM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
What's a good way to hold the clutch from turning without damaging it while trying to pull it off using this method?
Re: How to remove clutch from RV-2 style A/C compressor? [Re: mantonas] #1013685
06/21/11 09:23 AM
06/21/11 09:23 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Strap wrench .
I don't remember it being particularly hard to get it off , impact wrench and held it with a gloved hand ???
Re: How to remove clutch from RV-2 style A/C compressor? [Re: JohnRR] #1013686
06/21/11 09:27 PM
06/21/11 09:27 PM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
I keep forgetting I own an impact wrench! I'll try that.
Re: How to remove clutch from RV-2 style A/C compressor? [Re: mantonas] #1013687
06/21/11 10:47 PM
06/21/11 10:47 PM
Knoxville, TN, USA
mantonas Offline OP
mantonas  Offline OP
Knoxville, TN, USA
Just went out and did it with my impact wrench - worked like a charm!
Re: How to remove clutch from RV-2 style A/C compressor? [Re: mantonas] #1013688
06/21/11 10:59 PM
06/21/11 10:59 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Now that you already got it off I guess I don't need to tell how to hold it Next time take an old fan belt wrap it around the compressor pulley and put the long loop other end into a vise and pinch the belt until it is firmly in the pulley groove........
