How to remove clutch from RV-2 style A/C compressor?
#1013675
06/15/11 09:16 AM
06/15/11 09:16 AM
Posts: 395 Knoxville, TN, USA
mantonas
Knoxville, TN, USA
Is the clutch pressed on like a harmonic balancer, or should it come off when you remove the one bolt in the center?
69 Chrysler 300 Convertible
77 Chrysler New Yorker Brougham 2-dr
03 Jeep Grand Cherokee Limited
Re: How to remove clutch from RV-2 style A/C compressor?
[Re: gtx6970]
#1013677
06/15/11 11:01 AM
06/15/11 11:01 AM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
most I've seen there is a 5/16" bolt ( 1/2" hex head ) holding the clutch on. Remove said bolt and then the clutch is threaded. I think the threads are something like 5/8"
Just thread the large bolt in and it pulls the clutch off
What Bill said. The clutch is on a tapered shaft/crank end and you will need to "push" (or pull ) it off with a larger bolt. BTW all of the bolts are right-hand threads....
MikeR
[Re: A12]
#1013680
06/15/11 11:48 AM
06/15/11 11:48 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
on my 74 ( earliers too ) the clutch its pressed in to the bearing, inside the pulley.
the 1/2" hex head bolt in the middle just holds the complete clutch/pulley assembly into the tappered crank shaft
I remember have seen a thread somewhere around though, but had to remmove it with a press. Long time I did that!
Note, my assembly is with the smaller diameter pulley, not the big pulley like 60s models. Maybe there is the difference
[Re: NachoRT74]
#1013682
06/15/11 01:51 PM
06/15/11 01:51 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Ive removed quite a few using my deadblow hammer.I just remove the center nut then tap around the backside of the clutch.Ive never had one that wouldnt come off with some light tapping.One from my Imp sat for probally 10 years in the garage.A few taps and it slid off.Rocky
Chrysler Firepower
[Re: John_Kunkel]
#1013684
06/21/11 08:28 AM
06/21/11 08:28 AM
mantonas
Knoxville, TN, USA
What's a good way to hold the clutch from turning without damaging it while trying to pull it off using this method?
[Re: JohnRR]
#1013686
06/21/11 09:27 PM
06/21/11 09:27 PM
mantonas
Knoxville, TN, USA
I keep forgetting I own an impact wrench! I'll try that.
[Re: mantonas]
#1013687
06/21/11 10:47 PM
06/21/11 10:47 PM
mantonas
Knoxville, TN, USA
Just went out and did it with my impact wrench - worked like a charm!
[Re: mantonas]
#1013688
06/21/11 10:59 PM
06/21/11 10:59 PM
A12
N.E. OHIO, USA
Now that you already got it off I guess I don't need to tell how to hold it Next time take an old fan belt wrap it around the compressor pulley and put the long loop other end into a vise and pinch the belt until it is firmly in the pulley groove........
