440 source roller rockers who runs them? #1009734
06/08/11 11:59 PM
06/08/11 11:59 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
i know its been beat to death but the big block rocker arm choices keep on going and i know that td/jesel/harland sharps are the best.
i am on a super budget and the 440 source rockers are in the price range.... any miles on them?? rd rather have a "bushed" rocker but the you hear too many bad things about the kmj or proforms. ive seen some guys run roller cams with the source rockers.. theres got to be some feedback by now! cam is solid with 325 open pressure
74 dart sport 440 www.Csucarbs.com
Re: 440 source roller rockers who runs them? [Re: shoebox] #1009735
06/09/11 07:31 AM
06/09/11 07:31 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
hey shoebox,
i used a set about 2 years ago on a customers car,he wanted it now not in two weeks.poor quality,came undone and threw a couple of pushrods - twice - whilst running the cam in.first time thought maybe i was faulty - second time i replaced them.adjuster screw locknuts wern't square to rocker adjuster ball showed wear/flat spots.this was with a purple 528(?)cam.
i run Crane golds in my motor,put Hughes rockers in the customers motor
the supplier did come to the party and refunded on them after a little argy bargy
good luck
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 440 source roller rockers who runs them? [Re: tex013] #1009736
06/09/11 10:01 AM
06/09/11 10:01 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
thanks for the reply.. thats cool.. im not going to get them. i dont like the bearings anyway. the proforms are on sale right now at jegs for 209 i might buy them just to see the fit and finish and if their not good send them back. i talked to one of their tech guys while back and he is a mopar guy with a 10 second RR (493) and he said they would be ok with under 450ish pressure and they did have some issues in the past. but they got them worked out and better adjusters etc etc. they are bushed now too. hummm
Re: 440 source roller rockers who runs them? [Re: shoebox] #1009737
06/09/11 10:19 AM
06/09/11 10:19 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
$200.00 rocker arms... i would just run stock ones...
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 440 source roller rockers who runs them? [Re: Old School] #1009738
06/09/11 10:40 AM
06/09/11 10:40 AM
Idaho
Runner Offline
Runner  Offline
Idaho
why not use a set of crane or isky iron rockers?
Re: 440 source roller rockers who runs them? [Re: Old School] #1009739
06/09/11 10:43 AM
06/09/11 10:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would check into the Proforms as I have heard some bad things about them. I would either use Ductile iron rockers or spring the $350 and up for a good rockers. The eng I just put in my 63 is the first time I have ever used roller rockers as the ductile iron rockers have done good for me over the years. Sure good rollers are the best but you will pay a bit for good rollers. I ended up using Hughes roller rockers in my 493 that my brother had bought but ended up he didn't need them as his cust had already bought rockers. They are working great for me and he paid just over $400 I believe. Good luck , Ron
These are the Hughes I used.
Re: 440 source roller rockers who runs them? [Re: 383man] #1009740
06/09/11 10:46 AM
06/09/11 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: 440 source roller rockers who runs them? [Re: shoebox] #1009741
06/09/11 12:24 PM
06/09/11 12:24 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I've said it before but it does bare repeating.
"Rocker arms are probably the worst possible thing to buy the cheapest you can find". If you absolutely must have roller rockers then avoid anything that costs less than $500. RAS, Crane, Hughes, Sharpe, T&D, and Jessel are worth looking at. If you have less than .600 lift then ductile iron rockers from Isky or Crane will last forever on a decent set of hard shafts and can often be found in good used condition about as cheap as the Chinese junk rockers.
Re: 440 source roller rockers who runs them? [Re: GomangoCuda] #1009742
06/09/11 02:46 PM
06/09/11 02:46 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I agree one should run a quality rocker considering the task they have to do, my preference are the Harland Sharps. But I would temper the recommendation of the Crane ductile iron rockers, these traditionally have been reliable however..
About 4 years back before Crane when out of biz and while Mopar was selling a set of these they had some bad production runs of these that were not properly hardened and were defective..
So check carefully before putting down the $...
Just my $0.02...
Re: 440 source roller rockers who runs them? [Re: Sinitro] #1009743
06/09/11 03:13 PM
06/09/11 03:13 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I had a set of ductile cores to send to ras but total investment
Would have been 450ish and for that money you can have a good
Set of roller rockers that arent going to scrub the valves
Re: 440 source roller rockers who runs them? [Re: shoebox] #1009744
06/09/11 03:33 PM
06/09/11 03:33 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Makes me want to go hydraulic! Probably just as fast with HD stamped
Rockers! Someone buy this solid cam lol
Re: 440 source roller rockers who runs them? [Re: Sinitro] #1009745
06/09/11 04:08 PM
06/09/11 04:08 PM
Idaho
Runner Offline
Runner  Offline
Idaho
Just my $0.02...
my understanding is, it was the adjusters that were soft not the rockers, thats why i bought smith brothers adjusters when i bought my crane iron rockers
Re: 440 source roller rockers who runs them? [Re: Runner] #1009746
06/09/11 05:25 PM
06/09/11 05:25 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I've been running them for about 5 years now. The quality is not too good, and I'm planning on replacing them next month with Comp's Pro Magnum roller rockers. I've seen quite a few posts here on Moparts about them (and photographs!) that just scare me. I'm sure someone will post some carnage photos soon...
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: 440 source roller rockers who runs them? [Re: 1968RR] #1009747
06/09/11 08:13 PM
06/09/11 08:13 PM
organ
maximum entropy Offline
organ
i used a set on a customer engine at his insistence. that was about 4 years and maybe 1000 miles or so? the shafts were full of polishing compound. I MEAN FULL! the quality was scary. i don't know why people spend $1500.00 on a good crank, 800.00 on good pistons, and then cry about spending money WHERE MOST FAILURES OCCUR!
Re: 440 source roller rockers who runs them? [Re: maximum entropy] #1009748
06/09/11 09:05 PM
06/09/11 09:05 PM
okla.
sam64 Offline
sam64  Offline
okla.
then go buy andy f's book and look at all the variances between manufactures and you'll scratch your head a little more.
Re: 440 source roller rockers who runs them? [Re: tex013] #1009749
06/09/11 10:20 PM
06/09/11 10:20 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Looks like nothing works for you guys, only the high dollars parts. I've been using 440 source rocker in a customer's car with a roller cam and 630 lift. It's a low 10 second car at 3500 lbs. The arms have been there for almost two years with no problems at all and that car races almost twice a month.
Re: 440 source roller rockers who runs them? [Re: Runner] #1009750
06/10/11 12:10 AM
06/10/11 12:10 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Just my $0.02...
No...
The rocker tips were not hardened properly, the valve stems would eat in by several 0.00s...
Had extensive discussions with both Mopar and Crane even with their engineer @ SEMA, Crane just blew it off...
Just my $0.02...
Re: 440 source roller rockers who runs them? [Re: Sinitro] #1009751
06/10/11 12:55 AM
06/10/11 12:55 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I didnt read much of the other replies, but the Source Rockers use to be roller bearing... I would avoid these like a plague...
Look at these...
http://www.kmjent.com/cart/product.php?productid=445&cat=11233617&page=1
Id try these on a hyd, or small solid engine.
Re: 440 source roller rockers who runs them? [Re: Bob_Coomer] #1009752
06/10/11 01:20 AM
06/10/11 01:20 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Bob, there's been a couple of threads about bad experiences with those KMJ rockers; I've bought other stuff from them that was fine, and was looking at those in 1.6, but after reading those threads I'm looking at the Indy bushed aluminum roller-tip setup or the KMJ stainless setup. Ductile iron would be OK for my new 440 project, though they don't appear to be available as a kit with shafts & hardware.
Re: 440 source roller rockers who runs them? [Re: topside] #1009753
06/10/11 07:46 AM
06/10/11 07:46 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i built up a big block for my lawyers Jensen & used the source rocker arms. that was 3 years ago & he drives his jensen everywhere. to date he hasn't been back to say he had a problem. & with the spacers & hold downs there's no way the roller bearings can fall out so you can put an end to that myth.
