440 source roller rockers who runs them?
#1009734
06/08/11 11:59 PM
06/08/11 11:59 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
i know its been beat to death but the big block rocker arm choices keep on going and i know that td/jesel/harland sharps are the best.
i am on a super budget and the 440 source rockers are in the price range.... any miles on them?? rd rather have a "bushed" rocker but the you hear too many bad things about the kmj or proforms. ive seen some guys run roller cams with the source rockers.. theres got to be some feedback by now! cam is solid with 325 open pressure
Re: 440 source roller rockers who runs them?
[Re: shoebox]
#1009735
06/09/11 07:31 AM
06/09/11 07:31 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
hey shoebox, i used a set about 2 years ago on a customers car,he wanted it now not in two weeks.poor quality,came undone and threw a couple of pushrods - twice - whilst running the cam in.first time thought maybe i was faulty - second time i replaced them.adjuster screw locknuts wern't square to rocker adjuster ball showed wear/flat spots.this was with a purple 528(?)cam. i run Crane golds in my motor,put Hughes rockers in the customers motor the supplier did come to the party and refunded on them after a little argy bargy good luck Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 383man]
#1009740
06/09/11 10:46 AM
06/09/11 10:46 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
[Re: shoebox]
#1009741
06/09/11 12:24 PM
06/09/11 12:24 PM
Posts: 4,727 Moved to N.E. Tennessee
GomangoCuda
I've said it before but it does bare repeating. "Rocker arms are probably the worst possible thing to buy the cheapest you can find". If you absolutely must have roller rockers then avoid anything that costs less than $500. RAS, Crane, Hughes, Sharpe, T&D, and Jessel are worth looking at. If you have less than .600 lift then ductile iron rockers from Isky or Crane will last forever on a decent set of hard shafts and can often be found in good used condition about as cheap as the Chinese junk rockers.
[Re: GomangoCuda]
#1009742
06/09/11 02:46 PM
06/09/11 02:46 PM
Posts: 5,445 So Cal
Sinitro
So Cal
I agree one should run a quality rocker considering the task they have to do, my preference are the Harland Sharps. But I would temper the recommendation of the Crane ductile iron rockers, these traditionally have been reliable however.. About 4 years back before Crane when out of biz and while Mopar was selling a set of these they had some bad production runs of these that were not properly hardened and were defective.. So check carefully before putting down the $...
Just my $0.02...
[Re: Sinitro]
#1009745
06/09/11 04:08 PM
06/09/11 04:08 PM
Posts: 3,095 Idaho
Runner
Idaho
Just my $0.02...
my understanding is, it was the adjusters that were soft not the rockers, thats why i bought smith brothers adjusters when i bought my crane iron rockers
[Re: Runner]
#1009746
06/09/11 05:25 PM
06/09/11 05:25 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I've been running them for about 5 years now. The quality is not too good, and I'm planning on replacing them next month with Comp's Pro Magnum roller rockers. I've seen quite a few posts here on Moparts about them (and photographs!) that just scare me. I'm sure someone will post some carnage photos soon...
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#1009747
06/09/11 08:13 PM
06/09/11 08:13 PM
Posts: 5,080 organ
maximum entropy
organ
i used a set on a customer engine at his insistence. that was about 4 years and maybe 1000 miles or so? the shafts were full of polishing compound. I MEAN FULL! the quality was scary. i don't know why people spend $1500.00 on a good crank, 800.00 on good pistons, and then cry about spending money WHERE MOST FAILURES OCCUR!
[Re: Runner]
#1009750
06/10/11 12:10 AM
06/10/11 12:10 AM
Posts: 5,445 So Cal
Sinitro
So Cal
Just my $0.02...
No... The rocker tips were not hardened properly, the valve stems would eat in by several 0.00s... Had extensive discussions with both Mopar and Crane even with their engineer @ SEMA, Crane just blew it off...
Just my $0.02...
