This is interesting.............................
#1009636
06/08/11 10:04 PM
06/08/11 10:04 PM
Thumperdart
State of confusion
So I plug the bypass off at my cell and my pump gauge and my dash mounted gauges both go past 15+ psi. So if my pump was bad how that be possible? It`s too late to call Aeromotive so I`ll phone em tomorrow but Cab had mentioned that it COULD be the regulator............wadda you guys think? Thankxxxxx.........
Re: This is interesting.............................
[Re: Thumperdart]
#1009637
06/08/11 10:37 PM
06/08/11 10:37 PM
Posts: 740 WA
JD Dart
WA
Make it a dead head system sounds like your using the wrong regulator for a bypass system.
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: Thumperdart]
#1009643
06/09/11 07:34 AM
06/09/11 07:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Sounds like a regulater problem. A relay if its failing will burn itself up pretty fast.
Does the Pump itself seem to run at a constant rpm.
The pump seems steady enuff but when I bypass it the pump and. reg. maintain about the same pressures.....like if I set the reg. to 8 psi, the pump shows about the same WHEN bypassed but the minute I plug the bypass, both gauges peg to 15+ psi.
Does anyone know what that pump is suppose to put out at max pressure... I would think that it should be well above 15 when dead headed
[Re: MR_P_BODY]
#1009644
06/09/11 09:02 AM
06/09/11 09:02 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Dom, i use mallory 4309 regulators for my junk. i love the design and how well they work. i'm not sure what you are using
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1009646
06/09/11 09:17 AM
06/09/11 09:17 AM
MR_P_BODY
I use a 4 port Mallory... very simple... a spring and a seat... I've been running the same one for years
[Re: mopar65]
#1009648
06/09/11 09:53 AM
06/09/11 09:53 AM
MR_P_BODY
Mike you have a p/n for the one you are useing? i am looking for one for my twin 650 holley dp for my tunnelram and am undecided which one to get. thanks Mopar65
No I dont.. not sure if they still make this one... it also has a boost reference port... when I bought it I know it came with 2 springs... 1 for carb low pressure and 1 for injected high pressure
[Re: Thumperdart]
#1009653
06/09/11 03:28 PM
06/09/11 03:28 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I had a Russell flat screen type filter ahead of my 11203 pump the whole time I ran it.
