This is interesting............................. #1009636
06/08/11 10:04 PM
06/08/11 10:04 PM
State of confusion
Thumperdart Offline OP
State of confusion
So I plug the bypass off at my cell and my pump gauge and my dash mounted gauges both go past 15+ psi. So if my pump was bad how that be possible? It`s too late to call Aeromotive so I`ll phone em tomorrow but Cab had mentioned that it COULD be the regulator............wadda you guys think? Thankxxxxx.........
Re: This is interesting............................. [Re: Thumperdart] #1009637
06/08/11 10:37 PM
06/08/11 10:37 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Make it a dead head system sounds like your using the wrong regulator for a bypass system.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: This is interesting............................. [Re: Thumperdart] #1009638
06/08/11 11:00 PM
06/08/11 11:00 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Sounds like a regulater problem. A relay if its failing will burn itself up pretty fast.
Does the Pump itself seem to run at a constant rpm.
Re: This is interesting............................. [Re: Thumperdart] #1009639
06/09/11 02:49 AM
06/09/11 02:49 AM
So I plug the bypass off at my cell and my pump gauge and my dash mounted gauges both go past 15+ psi. So if my pump was bad how that be possible? It`s too late to call Aeromotive so I`ll phone em tomorrow but Cab had mentioned that it COULD be the relay............wadda you guys think? Thankxxxxx.........
Regulator, not relay. Sorry for the background noise on my cell phone It worked okay for a while, something is dying or getting FUBAR Let us know what you find out
Re: This is interesting............................. [Re: Sport440] #1009640
06/09/11 03:50 AM
06/09/11 03:50 AM
State of confusion
State of confusion
Sorry guys............I meant regulator.
Re: This is interesting............................. [Re: JD Dart] #1009641
06/09/11 03:52 AM
06/09/11 03:52 AM
State of confusion
State of confusion
I`m using a bypass reg. and it`s been fine for months and just started acting up.
Re: This is interesting............................. [Re: Sport440] #1009642
06/09/11 03:55 AM
06/09/11 03:55 AM
State of confusion
State of confusion
The pump seems steady enuff but when I bypass it the pump and. reg. maintain about the same pressures.....like if I set the reg. to 8 psi, the pump shows about the same WHEN bypassed but the minute I plug the bypass, both gauges peg to 15+ psi.
Re: This is interesting............................. [Re: Thumperdart] #1009643
06/09/11 07:34 AM
06/09/11 07:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Does anyone know what that pump is suppose to put
out at max pressure... I would think that it should
be well above 15 when dead headed
Re: This is interesting............................. [Re: MR_P_BODY] #1009644
06/09/11 09:02 AM
06/09/11 09:02 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Dom, i use mallory 4309 regulators for my junk. i love the design and how well they work. i'm not sure what you are using
Re: This is interesting............................. [Re: sixpackgut] #1009645
06/09/11 09:11 AM
06/09/11 09:11 AM
Arizona
Chris'sBarracuda Offline
Arizona
Hey Dom..
I've been bitten by regulators.. Some are a nightmare..
Anyway, I tried this one, and it is the best I've ever used.. A little pricey, but worth it..
Absolutely the most stable fuel pressure I've ever had..
http://aeromotiveinc.com/products-page/r...port-regulator/
Chris..
Re: This is interesting............................. [Re: sixpackgut] #1009646
06/09/11 09:17 AM
06/09/11 09:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a 4 port Mallory... very simple... a spring and
a seat... I've been running the same one for years
Re: This is interesting............................. [Re: MR_P_BODY] #1009647
06/09/11 09:23 AM
06/09/11 09:23 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Mike you have a p/n for the one you are useing? i am looking for one for my twin 650 holley dp for my tunnelram and am undecided which one to get. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: This is interesting............................. [Re: mopar65] #1009648
06/09/11 09:53 AM
06/09/11 09:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No I dont.. not sure if they still make this one...
it also has a boost reference port... when I bought
it I know it came with 2 springs... 1 for carb low
pressure and 1 for injected high pressure
Re: This is interesting............................. [Re: Thumperdart] #1009649
06/09/11 10:45 AM
06/09/11 10:45 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dom, have you called Aeromotive about this?
Re: This is interesting............................. [Re: MR_P_BODY] #1009650
06/09/11 12:57 PM
06/09/11 12:57 PM
State of confusion
State of confusion
They say the pump should put out 14 psi which makes me think I could run it deadheaded. I`m using the Aeromotive 4-port bad dog reg. but was thinking that when I plug the bypass it not really deadheaded properly so I`ll call em now and report back. Thankxxx guys..........
Re: This is interesting............................. [Re: Thumperdart] #1009651
06/09/11 01:30 PM
06/09/11 01:30 PM
State of confusion
State of confusion
Called Aeromotive and he told me my system is doing what it`s supposed to be doing w/my basic non running test. When I set the reg. for 8lbs and the pump shows the same, it`s doing it`s job and the bypass is working and so is the reg. He suggest I get rid of the Earls screen filter for now and run it and if it`s still jacked the pump has been compramised(fubared)and to send it in. Aeromotive pumps do NOT want a flat screen type filter before em PERIOD.......His words.
Re: This is interesting............................. [Re: Thumperdart] #1009652
06/09/11 03:11 PM
06/09/11 03:11 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I dunno... i run the 40 micron russel and
deadhead system... flat screen type filter.
http://www.summitracing.com/parts/RUS-650100/
Mopar Performance
Re: This is interesting............................. [Re: Thumperdart] #1009653
06/09/11 03:28 PM
06/09/11 03:28 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I had a Russell flat screen type filter ahead of my 11203 pump the whole time I ran it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: This is interesting............................. [Re: moparniac] #1009654
06/19/11 02:40 PM
06/19/11 02:40 PM
State of confusion
State of confusion
Well,it definately didn`t work for me. And after re- evaluating my fuel system which was plumbed after many `s, I ran braided from the cell into a y and directly attatched to the pump and what a difference. Before I had rubber hose clamp junk tied into 1/2" alum. which according to Aeromotive, creates flow issues.
Re: This is interesting............................. [Re: Thumperdart] #1009655
06/19/11 02:45 PM
06/19/11 02:45 PM
SoCal
Brian Hafliger Offline
SoCal
has caused me a few flubs along the way too....LOL!
Brian Hafliger
