Page 1 of 3 1 2 3
manual trans question #1009081
06/08/11 11:15 AM
06/08/11 11:15 AM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
hello... I am looking for opinions on a shifting problem I have been having with my '70 'cuda. The rods appear to be installed and aligned correctly. With the car at rest, it appears I can reach all gears and reverse. However, while in motion going from 1st to 2nd is a problem. I can only get into 2nd gear intermittently and most of the time it won't go in. I can however, go from 1st to 3rd or 4th, then back into 2nd. I can also start out in 2nd.
- The fluid is non-synthetic valvoline (or other) 80-90w.
- The shifter was rebuilt by me with new internal parts and appears to be working well.
- I also replaced the 1-2 operating lever because it had some play.
I bought the car with the trans problem. My initial thoughts were a rod alignment, but after a closer look, I decided to rebuild the shifter. And while that made a big improvement, it didn't cure the 2nd gear problem.
I have not pulled the sidecover, but at this point, I'm thinking 1-2 shifter fork????
Any thoughts would be very much appreciated, I'd like to drive this thing .
Thank you - Jerry
Re: manual trans question [Re: EF8aar] #1009082
06/08/11 11:43 AM
06/08/11 11:43 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Did you try adjusting the clutch?
Also is the fluid in the trans GL-4 or GL-5?
Re: manual trans question [Re: Cuda340] #1009083
06/08/11 11:48 AM
06/08/11 11:48 AM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
Thank you for responding ..
No, I hadn't thought of adjusting the clutch. The car does not have an overcenter spring either, if that matters at all..
The fluid was in the trans when I bought the car. The prior owner told me it was valvoline 80-90w nothing further..
Re: manual trans question [Re: EF8aar] #1009084
06/08/11 12:04 PM
06/08/11 12:04 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Does it grind or not go in to 2nd? Also adjustment of the clutch may help with the input shaft not spinning. If the oil is not GL-4 spec the slider won't grab the syncro as good as it should and it will be tough to shift. Just a couple of quick things to look at, before you tear into the trans. As far as the overhead spring being gone if it is a diaphram style clutch the it is supposed to be gone.
Re: manual trans question [Re: Cuda340] #1009085
06/08/11 12:22 PM
06/08/11 12:22 PM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
It does not grind, it just will not go in. It will go into 2nd from 1st at a crawl, but under acceleration or any rate of speed about >5mph, it won't go in.
I do not know what type of clutch is in the car.
If I adjust the clutch, am I looking for a higher or lower pedal?
Thank you for your help
Re: manual trans question [Re: EF8aar] #1009086
06/08/11 12:50 PM
06/08/11 12:50 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Actually you want to measure the air gap between the clutch disc and/or the flywheel or pressure plate with the pedal fully pressed in. It should be about .060" or so for the proper clearance. The higher the pedal goes the more stroke and the more clearance will be gained.
Re: manual trans question [Re: EF8aar] #1009087
06/08/11 01:30 PM
06/08/11 01:30 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
I had the same problem with 3rd gear in my Road Runner, no grinding, it just wouldn't go into gear most of the time. I did the same thing as you, adjust rods and rebuild shifter, but neither fixed the problem. I pulled the trans and found the 3-4 synchro sleeve worn. I replaced it and it shifts perfectly now. Hope this helps.
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: manual trans question [Re: D149] #1009088
06/08/11 01:50 PM
06/08/11 01:50 PM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
both of you have brought me great advise... thank you
I will try adjusting the clutch, then if that dosen't do it I'll pull the cover and take a peak inside.
Is is possible to see if the synchro sleeve is worn just from pulling the cover?
Re: manual trans question [Re: EF8aar] #1009089
06/08/11 03:13 PM
06/08/11 03:13 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I am assuming by the syncro sleeve he is refering to the slider. If so you can see if the ends are all chewed up, but more than likely it will be the brass syncro itself. The brass syncros are made to be sacrificial (brass is softer than steel) make sure all the dog teeth of the syncro are good and all the dog teeth on the gear are good. The should be sharp looking not with a smooth face. It sounds to me like the syncro is not grabbing the gear enough and that can be due to the oil not being GL-4 rated. If it is GL-5 it has too many friction modifiers in it and it is too slippery and won't let the syncro grab the gear hub.
Hope this helps.
Re: manual trans question [Re: Cuda340] #1009090
06/08/11 03:40 PM
06/08/11 03:40 PM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
This is good... Ok, so if I understand you correctly, I should check condition of the dog teeth of the syncro and all the dog teeth on the gear. If they look good, perhaps a change of fluid to a GL-4 type could solve it?
I think I will check the clutch as you said earlier and revisit my linkage one more time before cracking the case.
Thank you!
Re: manual trans question [Re: EF8aar] #1009091
06/08/11 04:03 PM
06/08/11 04:03 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Yes sir. that's it. I would even try and change the fluid before cracking the case, it's easier and it might just work.
Re: manual trans question [Re: Cuda340] #1009092
06/08/11 04:43 PM
06/08/11 04:43 PM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
excellent
Thank you!
Re: manual trans question [Re: EF8aar] #1009093
06/08/11 04:51 PM
06/08/11 04:51 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
It may not be relevant but under really hard acceleration it can be hard to get it into 2nd gear dur to worn/loose motor mount insulators.
Re: manual trans question [Re: Dean_Kuzluzski] #1009094
06/08/11 05:28 PM
06/08/11 05:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
My vote goes to a bad syncro. If fluid was the problem it would likely be an issue with all gears, not just second !! Clutch ... shouldn't be an issue if you have about an inch of freeplay in the pedal.
Ideally the syncro teeth should all be sharp - both the steel and the brass. However, I've had a few trannys with bad steel teeth and they've all worked fine once new brass rings were installed.
The problem with replacing the "steel" parts is the extent and expense. Its one thing to replace a slider/ring assembly but they're only half the equation ... the other half is the syncro teeth on each gear! If they're worn on the slider then the corresponding teeth on the gear should be shot too! Start replacing all the steel parts that have worn teeth and you may as well buy a new trans!
Pull the side cover, drop the driveshaft, yank the tailstock and replace all the brass rings, reassemble and drive it for years.
Re: manual trans question [Re: Stanton] #1009095
06/08/11 07:09 PM
06/08/11 07:09 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
i had the problem a while back trying to shift at high rpm from 1st to 2nd,shifted ok just riding around, found the bushing in the crank was very tight(actually pulled out of crank when i removed the trans)so the syncs could not slow the speed of the shaft to shift.i put the roller bearing that fits where the conv snout goes and worked great. fixed the problem i had.
Re: manual trans question [Re: cudaman1969] #1009096
06/09/11 10:32 AM
06/09/11 10:32 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Good Point!!!
Re: manual trans question [Re: Stanton] #1009097
06/09/11 10:34 AM
06/09/11 10:34 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Another Good Point!!! Although if it is an 18 spline I believe you have to drop the cluster gear to remove tailshaft/stock.
Re: manual trans question [Re: Cuda340] #1009098
06/09/11 11:48 AM
06/09/11 11:48 AM
New York
EF8aar Offline OP
EF8aar  Offline OP
New York
I took a closer overall look at the trans last night. I see evidence of a fresh pinkish color RTV most notibly at the reverse detent bolt area. Therefore, I think this box has been opened and I'll need to pull the cover to see what's going on.
Thank you for all the excellent responses
Re: manual trans question [Re: EF8aar] #1009099
06/09/11 02:11 PM
06/09/11 02:11 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Think about what you just said ... if you had to drop the cluster to get the taistock out that would mean it would also have to be dropped to put it back in. If so, how would you get the cluster shaft in after the tailstock is in ?!?!?! So no, you don't have to drop the cluster to get the tailstock out.
Re: manual trans question [Re: Stanton] #1009100
06/09/11 02:22 PM
06/09/11 02:22 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
If it were the case you would do it the same way you have to do it assembling an overdrive 833
Page 1 of 3 1 2 3
