manual trans question
#1009081
06/08/11 11:15 AM
06/08/11 11:15 AM
Posts: 149 New York
EF8aar
New York
hello... I am looking for opinions on a shifting problem I have been having with my '70 'cuda. The rods appear to be installed and aligned correctly. With the car at rest, it appears I can reach all gears and reverse. However, while in motion going from 1st to 2nd is a problem. I can only get into 2nd gear intermittently and most of the time it won't go in. I can however, go from 1st to 3rd or 4th, then back into 2nd. I can also start out in 2nd. - The fluid is non-synthetic valvoline (or other) 80-90w. - The shifter was rebuilt by me with new internal parts and appears to be working well. - I also replaced the 1-2 operating lever because it had some play. I bought the car with the trans problem. My initial thoughts were a rod alignment, but after a closer look, I decided to rebuild the shifter. And while that made a big improvement, it didn't cure the 2nd gear problem. I have not pulled the sidecover, but at this point, I'm thinking 1-2 shifter fork???? Any thoughts would be very much appreciated, I'd like to drive this thing . Thank you - Jerry
Re: manual trans question
[Re: EF8aar]
#1009082
06/08/11 11:43 AM
06/08/11 11:43 AM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Did you try adjusting the clutch? Also is the fluid in the trans GL-4 or GL-5?
[Re: Cuda340]
#1009083
06/08/11 11:48 AM
06/08/11 11:48 AM
Posts: 149 New York
EF8aar
New York
Thank you for responding ..
No, I hadn't thought of adjusting the clutch. The car does not have an overcenter spring either, if that matters at all..
The fluid was in the trans when I bought the car. The prior owner told me it was valvoline 80-90w nothing further..
[Re: Cuda340]
#1009085
06/08/11 12:22 PM
06/08/11 12:22 PM
Posts: 149 New York
EF8aar
New York
It does not grind, it just will not go in. It will go into 2nd from 1st at a crawl, but under acceleration or any rate of speed about >5mph, it won't go in.
I do not know what type of clutch is in the car.
If I adjust the clutch, am I looking for a higher or lower pedal?
Thank you for your help
[Re: EF8aar]
#1009087
06/08/11 01:30 PM
06/08/11 01:30 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
I had the same problem with 3rd gear in my Road Runner, no grinding, it just wouldn't go into gear most of the time. I did the same thing as you, adjust rods and rebuild shifter, but neither fixed the problem. I pulled the trans and found the 3-4 synchro sleeve worn. I replaced it and it shifts perfectly now. Hope this helps.
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
[Re: EF8aar]
#1009093
06/08/11 04:51 PM
06/08/11 04:51 PM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
It may not be relevant but under really hard acceleration it can be hard to get it into 2nd gear dur to worn/loose motor mount insulators.
[Re: cudaman1969]
#1009096
06/09/11 10:32 AM
06/09/11 10:32 AM
Cuda340
Wheatfield, NY
i had the problem a while back trying to shift at high rpm from 1st to 2nd,shifted ok just riding around, found the bushing in the crank was very tight(actually pulled out of crank when i removed the trans)so the syncs could not slow the speed of the shaft to shift.i put the roller bearing that fits where the conv snout goes and worked great. fixed the problem i had.
Good Point!!!
[Re: EF8aar]
#1009099
06/09/11 02:11 PM
06/09/11 02:11 PM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Although if it is an 18 spline I believe you have to drop the cluster gear to remove tailshaft/stock.
Think about what you just said ... if you had to drop the cluster to get the taistock out that would mean it would also have to be dropped to put it back in. If so, how would you get the cluster shaft in after the tailstock is in ?!?!?! So no, you don't have to drop the cluster to get the tailstock out.
[Re: Stanton]
#1009100
06/09/11 02:22 PM
06/09/11 02:22 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
If it were the case you would do it the same way you have to do it assembling an overdrive 833
