Re: fuel pump question/problem- help
[Re: CharlieB]
#1007821
06/07/11 06:49 PM
06/07/11 06:49 PM
Posts: 344 PA
noplanb
PA
I'd replace it, ain't gonna grow back. It will only get worse.
remember when you said honey, some day that car is gonna look so good in front of our house
[Re: CharlieB]
#1007822
06/07/11 06:54 PM
06/07/11 06:54 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
OK so I finally got the pump rod out- do not have anything more precise than a ruler but if 3.25 is correct lenght it is a strong 1/16 to 1/8 short and shows signs of wear on the end. Whats the verdict??
Is it a new rod or a reused original ?
[Re: JohnRR]
#1007823
06/07/11 06:57 PM
06/07/11 06:57 PM
Posts: 1,301 Edgartown, MA/ Greene, ME
CharlieB
Not sure if the shop replaced during rebuild, but I've put 32,000 miles on it in 5 years.
[Re: JohnRR]
#1007824
06/07/11 06:58 PM
06/07/11 06:58 PM
Posts: 15,487 Florida
scratchnfotraction
still the stock cam?
has the 383 ever been apart?
[Re: scratchnfotraction]
#1007825
06/07/11 07:05 PM
06/07/11 07:05 PM
CharlieB
complete stock rebuild 30 over 5 years ago
[Re: CharlieB]
#1007826
06/07/11 09:15 PM
06/07/11 09:15 PM
RapidRobert
Yes replace it & not sure of the depth of the hardenening (assuming it is hardened on the ends) & there was a comprehensive thread on the best rod to get as some brand new rods ain't no good/won't last
[Re: CharlieB]
#1007830
06/07/11 11:34 PM
06/07/11 11:34 PM
scratchnfotraction
pull the coil wire,have some one spin it a good few spins and see how much it moves,pushing the rod against the cam lobe with a finger. any wear marks on the side of rod to indicate how much movment it has been moveing? most likly nothing wrong with the cam,good to double check it while your there go on the race board and ask which rod is best,they will know
