MALLERY/ACCEL question #1003360
05/31/11 12:31 AM
05/31/11 12:31 AM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
hello
Im working on a 69 barracuda 440 4 speed
dos any one know how to wire this ignition up
some pics
thanks
1.39 9.85 - 137 mph
Re: MALLERY/ACCEL question [Re: Ari440] #1003361
05/31/11 01:40 AM
05/31/11 01:40 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
hey Ari440 how have you been? i have been fine hoping to go to the trick this coming weekend for the frist time this year. but to answer your question here is a link to summits web site. just click on the instructions and it will show you how. thanks Mopar65
http://www.summitracing.com/parts/MAA-3757801/?rtype=1
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: MALLERY/ACCEL question [Re: Ari440] #1003362
05/31/11 03:31 AM
05/31/11 03:31 AM
My on Mallory Unilites is don't use them , They (the light)will fail without warning I ahev seen it happen way to many tiimes for it to be a odd occurance, way to many times.You would be better off with a stock point distributor Any progress on getting that intake and carb. set up running yet?
Re: MALLERY/ACCEL question [Re: Cab_Burge] #1003363
05/31/11 06:42 AM
05/31/11 06:42 AM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
thank you BOBBY
CAB this car has been sitting for 15 years ,the guy asked me to put it together , moter trannie where in the car , he couldnt finish it off
this is what I have to work with for now
the sixpack is working fine ,got a car show troffy (sp) for it
car is faster then a 1050 carb on it
1.39 9.85 - 137 mph
Re: MALLERY/ACCEL question [Re: Ari440] #1003364
06/05/11 09:39 PM
06/05/11 09:39 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
hi
Im having a problem with the igntion system
have very low voltage at the coil and very weak spark / will not start
this was a 340 car ,is the blue wire for the coil
check the ballast rissiter (sp) power going througth it
any other ideas where to check
EDIT / ALSO whould the ignition swicth give you low voltage
1.39 9.85 - 137 mph
Re: MALLERY/ACCEL question [Re: Ari440] #1003365
06/05/11 10:17 PM
06/05/11 10:17 PM
Call Mallory fro trouble shooting help
Re: MALLERY/ACCEL question [Re: Cab_Burge] #1003366
06/05/11 10:28 PM
06/05/11 10:28 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
could it be not the mallory ignition problem , but the car itself
1.39 9.85 - 137 mph
Re: MALLERY/ACCEL question [Re: Ari440] #1003367
06/05/11 10:54 PM
06/05/11 10:54 PM
mopar65 Offline
mopar65  Offline
could be. what voltage are you getting on the brown wire while you are cranking it? the blue wire should be around 9 volts with the key in the run postions. but i do agree with cab i dont really care for the unalite dist. i ahd one in a small block dart that just quit for some reasion.if you can get a stock dist i have a accel 300+ you can have.
here is the wireing diagram for the car you are working on.
http://www.mymopar.com/downloads/1969/69BarracudaB.jpg
and here is the one for a 73 abody with electronic voltage regulator
http://www.mymopar.com/downloads/1973/73DartA.jpg
Re: MALLERY/ACCEL question [Re: mopar65] #1003368
06/05/11 11:50 PM
06/05/11 11:50 PM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
voltage at the ballist resister is 11 volts on the other side its 5 volts
where do I find the brown wire
the blue wire . I think is for the coil , is 5 volts
do I have the rigth wire or where sould I be looking for it
1.39 9.85 - 137 mph
Re: MALLERY/ACCEL question [Re: Ari440] #1003369
06/07/11 12:23 AM
06/07/11 12:23 AM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
a 69 440 4 speed barracuda ran today !!!
thank you for the help
1.39 9.85 - 137 mph
Re: MALLERY/ACCEL question [Re: Ari440] #1003370
06/07/11 12:57 AM
06/07/11 12:57 AM
mopar65 Offline
mopar65  Offline
cool glad you got her running. what did you find out was wrong with it? thanks Mopar65
Re: MALLERY/ACCEL question [Re: mopar65] #1003371
06/07/11 12:59 AM
06/07/11 12:59 AM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
the wire harnest going to the firewall not making good contact
1.39 9.85 - 137 mph
Re: MALLERY/ACCEL question [Re: Ari440] #1003372
06/07/11 01:07 AM
06/07/11 01:07 AM
mopar65 Offline
mopar65  Offline
congrats ARI glad you got her running.mopar65
Re: MALLERY/ACCEL question [Re: Ari440] #1003373
06/07/11 01:09 AM
06/07/11 01:09 AM
1969 was not a good year for Mopar cars wiring, especially the engine and under the hood harnesses I would, and do, recommend disconnecting the firewall gang plug and all the harnesses off of the firewall and clean all the contacts, both female and the males and then use dialectric grease on both sides when you reassemble it
Re: MALLERY/ACCEL question [Re: Cab_Burge] #1003374
06/07/11 01:16 AM
06/07/11 01:16 AM
long island NY
Ari440 Offline OP
Ari440  Offline OP
long island NY
thats what I did
some wires I sodierd (sp) too
the car had very poor work done to it
1.39 9.85 - 137 mph
